It is currently Thu Nov 21, 2024 5:38 am
[ 22 posts ] |
Littleton U Pull 2/13
2x 1996 V8 Exploders, both had the desirable GT40 heads still on them, one was complete.
1977 full width D44, high pinion w/ weld on wedges, someone botched a brake removal but the rest was there.
2x trucks w/ NP205s in them, hey Eck!
Several other V8 exploders is various condition.
Fri Feb 13, 2015 4:59 pm |
Re: Littleton U Pull 2/13
Keep your hands off the 5.8 in the 96 Bronco
Fri Feb 13, 2015 5:51 pm |
sykanr0ng
I was about to ask how you botch a brake removal, but then remembered that some people could break an anvil in a sand pile.
Fri Feb 13, 2015 5:58 pm |
Fri Feb 13, 2015 7:14 pm |
Can I ask why a 205? Other than being strong as hell they suck ass. only a 1.95:1 low range.
Fri Feb 13, 2015 7:43 pm |
Fri Feb 13, 2015 8:01 pm |
205 is only good with a 203 in front of it. The dana 20 is plenty strong for normal bronco use and about half the weight. I'd rather have the lower gearing.
Fri Feb 13, 2015 9:21 pm |
Fri Feb 13, 2015 9:49 pm |
atlas time
Fri Feb 13, 2015 9:50 pm |
Im also wondering why no one has bothered to market a lower gear set for the 205 if it's so bullet proof.
Fri Feb 13, 2015 9:51 pm |
Fri Feb 13, 2015 9:54 pm |
Fri Feb 13, 2015 9:58 pm |
Fri Feb 13, 2015 10:02 pm |
Fri Feb 13, 2015 10:04 pm |
Fri Feb 13, 2015 10:08 pm |
Thanks- I haven't done a lot of research yet but that's a definite option. I mean, I just got my rig drivable today so I don't plan to do this anytime too soon.
Fri Feb 13, 2015 10:13 pm |
Fri Feb 13, 2015 10:47 pm |
(Fingers in ears) Lalalalalala!
Fri Feb 13, 2015 11:00 pm |
Kirk, did you see the 1970 F250 Camper Special with the camper on it ?
It was off to the right before you entered.
Sat Feb 14, 2015 1:03 pm |
Why yes I did, had a sign on it that said "runs" I think, looked to be in good condition, 2wd.
Sat Feb 14, 2015 1:59 pm |
sykanr0ng
Sat Feb 14, 2015 6:01 pm |
Sun Feb 15, 2015 8:45 am |
[ 22 posts ] |
