It is currently Mon Nov 25, 2024 1:20 am
project viperwolfe is starting
Re: project viperwolfe is starting
Went to the wrecking yard to find a timing cover, upper intake and some other assorted parts. I got the intake and assorted parts. Timing cover was held solid with the two bolts that broke and wouldn’t come off in one piece. It wasn’t worth the time to try to pull another so I bought a new one. Once the timing cover is on I can check the timing marks and put the heads on. Test fitting the coil bracket showed that a little work was needed to fit it to the new lower. The legs were easily bent outward for the wider manifold. The top attachment needed to be raised about 1”. I cut a section out and welded the tab back on. Also had to grind some clearance for the fuel rail and heater fitting. 20150129_181557.jpg 20150129_181624.jpg
Sat Jan 31, 2015 4:32 am |
Moab Mike
Lookin' good! I was over at Mike's last night and saw the progress on your body. Your going to have a really nice bronco when it's done.
Sat Jan 31, 2015 9:42 am |
Definitely, can't wait to see it!
Sat Jan 31, 2015 10:28 pm |
Holy updates Batman.
Sat Jan 31, 2015 10:47 pm |
Got the new timing cover and water pump in. Timing cover was Dorman 635-106, made in china of course. Outward appearance is nicer than the factory covers with less rough edges and a smoother casting. The problem area appeared when I tried to use the alignment dowels. The two lower holes are not spaced far enough apart to use both dowels. So I ended up using the one that would allow all the other bolt holes to line up.
No problems with the water pump, Duralast CWP-9047. It's a new pump but it was about $20 cheaper than a rebuilt and a core charge.
Got it all on and verified the balancer timing then added the timing tape. Had to get creative to find a way to attach the degree wheel with the balancer and water pump in the way. 20150131_194639.jpg 20150131_194653.jpg 20150131_200409.jpg
Sat Jan 31, 2015 11:57 pm |
I'm ing..............keep em coming
Sun Feb 01, 2015 6:43 am |
Looks good. when you bringing it home?
Sun Feb 01, 2015 7:48 am |
Sun Feb 01, 2015 1:46 pm |
Looking very nice! Can't wait to see the finished project!
Sun Feb 01, 2015 2:14 pm |
EFI Guy
Sweet! I guess I'll add another update. Your PCM is done and tested, your harness is stuck at 99.9999 percent completion until I can swing by the boneyard for 1 little clip.
Sun Feb 01, 2015 3:55 pm |
Sun Feb 01, 2015 4:15 pm |
EFI Guy
It's an NRT1 (the most common 98 code). Or, you can use EDS0, EDS1 EDS2, PCC1, MCR0, MCR1, MCR2.
Sun Feb 01, 2015 7:18 pm |
777mechanic
finally have sometime to post up pics of where i'm at with body , hope to start frame soon so we can have a roller .
Mon Feb 02, 2015 4:04 pm |
777mechanic
some more pics
Mon Feb 02, 2015 4:06 pm |
Woodscaper
Joined: Fri Nov 19, 2010 11:16 pm Posts: 587 Location: Lakewood/Green Mtn.
Its looking really good guys.
Wed Feb 04, 2015 9:46 am |
A little more progress. I blinged out the upper manifold and built an engine transport and storage fixture. 20150203_170239.jpg 20150206_180007.jpg
Fri Feb 06, 2015 11:55 pm |
Looking great would love to see it before you start putting the body together.
Sat Feb 07, 2015 8:26 am |
B.O.B.
What did you spray the inner tub with?
Sat Feb 07, 2015 8:51 pm |
No real progress to report. Still waiting for a few parts. Might as well get started on the 4r70w.20150212_193142.jpg
Thu Feb 12, 2015 9:42 pm |
Moab Mike
NICE!
Thu Feb 12, 2015 9:44 pm |
"Here's a casual teaser shot of a ZF I have."
Looking good for sure. I need to get me one of those obsessive tendencies towards garage cleanliness and organization.
Thu Feb 12, 2015 9:48 pm |
Looking good Phil! I also like that teaser shot of the ZF5.
Thu Feb 12, 2015 10:03 pm |
Thu Feb 12, 2015 11:49 pm |
When ya moving back home?
Fri Feb 13, 2015 6:11 am |
Can't afford to until I stop bleeding from my wallet, I mean finish putting this Bronco together.
Got some plug wires installed. Started on the 4R70W. Looks good inside. Nothing broke but I can still make some improvements. 20150214_151239.jpg 20150214_175503.jpg
Sun Feb 15, 2015 5:11 am |
Phil,
What headers are you going to use ?
Sun Feb 15, 2015 6:45 am |
I have some Sandersons sitting in Mike's attic, next to my Lokar 4R70W shift lever.
Sun Feb 15, 2015 12:47 pm |
This will be your 2nd 4R70W right?
Sun Feb 15, 2015 4:19 pm |
Sun Feb 15, 2015 4:39 pm |
Got the case and pan cleaned up. Installed a drain plug and ordered some good parts. IMG_3197.JPG IMG_3199.JPG IMG_3202.JPG
Wed Feb 18, 2015 11:15 pm |
Users browsing this forum: No registered users and 23 guests |
