It is currently Thu Nov 21, 2024 11:28 am
[ 19 posts ] |
Foam
I want to get some foam I can use to put in my Tuffy storage box.
You know, the kind you cut out so a handheld projectile launcher can be stored in it without banging around getting scratched up.
Don't know what kind to get and where to get it from.
Any ideas ?
Wed Mar 04, 2015 8:05 pm |
rt9
Re: Foam
You can check the packing supply houses that sell to business. You know boxes and such. They normally carry hi density foam in various sheet thickness and weight. They can usually cut it for you as well. Try PA or ULine.
Wed Mar 04, 2015 8:28 pm |
Re: Foam
I bought a pack of those foam gym mats. The kind that fit together like a puzzle. It's a pretty dense foam and I have some left if you want it. EDIT: http://www.walmart.com/ip/Gold-s-Gym-6- ... t/21672523 - what I have also, Grainger has stuff like this: http://www.grainger.com/product/GRAINGE ... =FFTS&pbi=
Wed Mar 04, 2015 8:41 pm |
71 Broncman
Re: Foam
Another option is Target, Wal*Mart, or somewhere similar and buy one of the foam mattress toppers and cut it to fit your needs. They can be had in different thicknesses and either egg crate style or memory foam. Another option is an upholstery supply place which has different densities and will probably sell whatever size you need. I know there is at least one place in the Springs and a greater number in the Denver area. Mark.
Wed Mar 04, 2015 9:51 pm |
Re: Foam
Camera or digital equipment places will have them for those waterproof/shockproof pelican cases. Check Amazon.
Wed Mar 04, 2015 11:59 pm |
sykanr0ng
Re: Foam
Military surplus stores usually sell foam.
I know Jax in Ft. Collins has it in several firmnesses.
Thu Mar 05, 2015 12:25 am |
Re: Foam
Thanks for the input fellas
Thu Mar 05, 2015 5:47 pm |
ManTruck
Re: Foam
I would suggest you look at the foam anti fatigue mat from Harbor Freight. 4 Squares for about $9. I use those for many things and they are cheap.
They are thin and will not eat too much space up in the tuffy. Just get some spray adhesive for the tuffy walls to hold in place.
When I do the late elk season I line the floor of the 5th wheel with them all trimmed into size etc for additional insulation and foot comfort for bare socks. My camper is sealed on the bottom and insulated but it makes it more comfortable. Cheap enough and durable too for many uses. I keep several around and when working under a vehicle on concrete and not using a creeper I will lay those out for comfort and padding as well.
_________________ Owned my 1972 since 1985
Canon City, Co
Fri Mar 06, 2015 8:31 am |
Re: Foam
Somebody else suggested I wrap the gun and mags in plastic (individually) and then spray expanding foam into the box, let it expand, and then press the objects into the expanded foam before it hardens.
Any thought on this approach ?
Fri Mar 06, 2015 10:00 am |
Re: Foam
Fri Mar 06, 2015 10:12 am |
Dukietown
Re: Foam
Fri Mar 06, 2015 10:15 am |
Re: Foam
Fri Mar 06, 2015 10:18 am |
Re: Foam
Why not just go to Home Depot and buy a sheet of concrete insulating styrofoam? Cuts easy and is cheap. Spray adhesive the top and line with a soft cloth material to finish it off.
The "pick and pluck" inserts for Pelican cases look great and aren't too bad, in theory. It does become a bit of a pain when you start looking at expanding your selection of packed firearms.
The sheet foam, non-precut, that Pelican offers is better. But it is nothing special. You can get very similar stuff from your local Joann Fabrics store. The high density stuff costs a little more. I bought a full sheet of 6"x36"x6' last year and it ran me around 80 bucks or so on super discount.
Fri Mar 06, 2015 1:21 pm |
Re: Foam
DO NOT use spray foam and plastic wrap. The foam will eat/burn through the plastic and get all over the gun.
Just do as others have said and mount a holster to the side.
Fri Mar 06, 2015 9:44 pm |
sykanr0ng
Re: Foam
I have seen a set-up with a heavily plastic coated rod that inserts into the barrel to hold your handheld kinetic energy applicator. Often used to hold one under a table or desk. It has the advantage of one size fits all (or nearly so)
Sat Mar 07, 2015 12:40 am |
Dirtheadz
Re: Foam
Sat Mar 07, 2015 6:44 am |
Re: Foam
the tuffy box I'm talking about is the lockable kind which resides under the passenger seat so I'm not really concerned about quick access (although the holster could still be a good solution) most often I would have it with me but I just need a place to secure it if I had to go inside somewhere that doesn't allow them or when carrying it isn't practical thanks for all the good ideas now I gotta go find me one of those plastic rods to mount under the table for when Maddy starts bringing boys home
Sat Mar 07, 2015 8:21 am |
sykanr0ng
Re: Foam
Sat Mar 07, 2015 9:53 am |
Re: Foam
If you really don't want any shenanigans going on, welcome him into the home and don't stop telling your daughter about how much you like him. If she's the type to want to piss you off, you're almost guaranteed to never see him again.
Sat Mar 07, 2015 10:08 am |
[ 19 posts ] |
Users browsing this forum: No registered users and 16 guests |
