www.ColoradoClassicBroncos.com - View topic - Here we go again...
It is currently Mon Nov 25, 2024 5:32 pm
Reply to topic  [ 73 posts ]  Go to page Previous  1, 2, 3  Next
 Here we go again...
Post Re: Here we go again...
Those are the same style marks I had on my 460 when the rockers rubbed the valve covers. I had to go to a "tall" valve cover to clear mine.
Fri Mar 13, 2015 6:02 am
Post Here we go again...
They are definitely rubbing. I suggested doubling up gaskets and do a short test to see if the noise goes away. If it does then he would know and could grind out the inside valve covers or get another taller set.
I think I remember this being an issue with the bronco script covers on efi engines from cb.com? I think I considered them, read about it and ended up going with ford powered mustang efi covers off eBay.
Fri Mar 13, 2015 7:45 am
These are similar to the ones I picked up but found my used
http://pages.ebay.com/link/?nav=item.vi ... 1614382170
NEW OEM Ford Racing Mustang Black Satin Valve Covers M6000J302R EFI SBF 302 351
Fri Mar 13, 2015 7:51 am
Fri Mar 13, 2015 9:24 am
they were probably $60 used ;)
i know they were way less than those posted, i think you have a good plan and it'll work out
Fri Mar 13, 2015 9:31 am
So it does not really appear that the rockers are making contact with the valve covers. I sort of feel as though I may have an exhaust leak making the noise. I took it around the block and I have very little power when I push hard on the skinny pedal. It also has a low throaty bog sound to it. It also seems like when I go from very little gas to pushing hard on it, there is a lull and almost like an air bubble it jumps over then accelerates. I have tightened down all of the header bolts, collector bolts and upper intake bolts.
I am just not good at diagnosing this stuff on my own. I have no experience and don't want to over analyze stuff unnecessarily. Can exhaust shops easily diagnose that type of thing? Any other thoughts from the experts out there?
Fri Mar 13, 2015 3:20 pm
Fri Mar 13, 2015 3:32 pm
But I don't think a leaking header gasket would cause the performance issue you describe
Fri Mar 13, 2015 4:56 pm
EFI Guy to the rescue. In a short time he was able to help me determine that the roll pin on the cam sensor gear had sheared off and so it wasn't spinning- hence no oil pressure with the cam synchro installed.
The good news is I wasn't crazy. The ok news is that it should hopefully be an easy fix. The undetermined news is whether the short time of driving it without active oil pressure did any real damage. The rockers are all still wet so it didn't run dry or anything....Image
Fri Mar 13, 2015 6:24 pm
How long do you suppose it was sheared off for?
Any idea what caused the shear?
Fri Mar 13, 2015 6:42 pm
Fri Mar 13, 2015 6:53 pm
Fri Mar 13, 2015 9:35 pm
Fri Mar 13, 2015 9:46 pm
I don't know. Did you ever post pictures of it?
Fri Mar 13, 2015 10:42 pm
Fri Mar 13, 2015 10:52 pm
What the heck would cause it to shear? That's kind of crazy never heard of gat happening. But glad you found it.
Fri Mar 13, 2015 11:58 pm
Sat Mar 14, 2015 7:27 am
I'm still suspicious of the tow.
Sat Mar 14, 2015 7:58 am
Sat Mar 14, 2015 10:22 am
I suspect the roll pin sheared because it did not go all the way through the gear, all of the load was placed on one end.
I'm not sure where I came up with the "Melonized Iron" term when researching it a while back, but this is from the engineering doc for the 3.8 sensor:
Sat Mar 14, 2015 10:56 am
Sat Mar 14, 2015 11:22 am
Sat Mar 14, 2015 11:23 am
Sat Mar 14, 2015 11:29 am
I would guess that the pin broke as a result of a sudden stop or change in direction.
Sat Mar 14, 2015 12:37 pm
high pressure oil pumps can cause early fatigue in cam gears. I've never seen one shear the pin.
Sat Mar 14, 2015 1:24 pm
Profile WWW
Sat Mar 14, 2015 1:32 pm
Sat Mar 14, 2015 5:52 pm
Sat Mar 14, 2015 7:29 pm
Sat Mar 14, 2015 7:37 pm
Mon Mar 16, 2015 10:06 am
Users browsing this forum: No registered users and 45 guests
33,078,467 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
