It is currently Thu Nov 21, 2024 2:00 pm
[ 15 posts ] |
Need to BORROW left hand drill bits
Anyone happen to have a set of good quality (read: NOT Harbor Freight) left hand drill bits? If so, I need to borrow them for an hour or two (hopefully). Not particularly interested in easy outs or other bolt extraction systems, but thanks.
Optimal time to borrow them would be this weekend (in case you're coming to breakfast from up north).
Tue Mar 17, 2015 9:20 pm |
cravenbronco
Re: Need to BORROW left hand drill bits
Tue Mar 17, 2015 9:54 pm |
Oh, about the size of the bolt that holds a crankshaft main cap into the bottom of a 350 SBC block and smaller. I'll get you a measurement in just a sec.
Tue Mar 17, 2015 9:56 pm |
Tue Mar 17, 2015 9:59 pm |
Tue Mar 17, 2015 10:01 pm |
The piece of the puzzle that does not fit is the 'C' in 'SBC'.
Tue Mar 17, 2015 11:13 pm |
I broke one of those in a 302 once. Miss-read the torque spec from a 351w. It came right out though.
Tue Mar 17, 2015 11:45 pm |
Wed Mar 18, 2015 12:23 am |
Wed Mar 18, 2015 12:25 am |
cravenbronco
Wed Mar 18, 2015 3:29 am |
Wed Mar 18, 2015 6:42 am |
HIX
Joined: Tue Feb 15, 2011 12:38 pm Posts: 174 Location: Wheat Ridge Colorado
So this is what I did in a similar situation since I never have good luck drilling out broken bolts...
Drill a hole in the broken bolt head Spray the hole with plastidip Drills small shallow hole in the broken shaft Hold the bolt head up against the broken bolt Weld the two together from the inside
Sounds retarded but it works. Stick welder is easier than mig, but I have done both
Thu Mar 19, 2015 9:13 am |
Thu Mar 19, 2015 9:47 am |
Wound up ordering a set of bits. Which was a waste of time. The threaded stub came out with a flat blade screwdriver. Guess I have bits for another day.
Sun Mar 29, 2015 8:08 pm |
[ 15 posts ] |
