www.ColoradoClassicBroncos.com - View topic - "best" body mount kit
It is currently Mon Nov 25, 2024 12:48 pm
Reply to topic  [ 13 posts ]
Post "best" body mount kit
Is there a best, or better, body mount kit.
WH sells a rubber set & a polyurethane set with "bigger" hardware.
Amazon has a poly set $20 & free shipping less than the WH sets (Energy Suspension).
Rubber vs poly?
Any reason to spend the extra for WH?
Sun Mar 29, 2015 8:37 pm
Rubber is squishy but can lead to rusty body mounts on the frame and body (not really an issue in Colorado). Poly is stiff but doesn't have the associated rust worries (again, Colorado). Rubber will begin to sag in about 15 years or so (unless today's rubber body mounts are better than the olden days). Poly will still be the exact same rigid thickness 1,000 years from now.
Personally, I like rubber. I put new rubber on the '66, never got around to replacing the '69, and will be going with rubber on the '72 and '73.
Are you running any body lift or planning to?
Sun Mar 29, 2015 11:53 pm
Post Re: "best" body mount kit
No body lift, yet. But if I want to clock my Atlas flat, I"ll need 2". That might probably happen with the jump from 33's to 37's in a year or two.
I just figure if I'm going to build a new front clip, I should start off on new body mounts. The 40 year old rubber ones are pretty deformed.
Mon Mar 30, 2015 7:34 am
I would probably run poly in your case. I don't even know if they make a body lift in rubber. Never looked into BL before. Also, if you're going to customize or rebuild the front clip you'll want some structural rigidity I would think.
Mon Mar 30, 2015 12:43 pm
One vendor make an integrated 1" body lift with mounts in poly. Might be something to think about if your going to raise it more in the future. Less pancake stacks like I have on my 69.
Mon Mar 30, 2015 2:44 pm
Post Re:
Mon Mar 30, 2015 5:16 pm
If you're looking to build on a rock solid platform, go with the poly bushings. When you install them use a torque wrench and set them all the same to make sure you are absolutely uniform. I have one you can have for free. ;)
Mon Mar 30, 2015 5:46 pm
Images: 11
Does somebody make this ? This weekend, I found out I could use this.CAM01274.jpg
Mon Mar 30, 2015 7:10 pm
Images: 11
Soory. That was a reply to landshark's poly with 1inch lift.
Mon Mar 30, 2015 7:11 pm
Wild Horses makes the "integrated kits", in 1" lift.
http://www.wildhorses4x4.com/product/Cu ... ft_Kit_1in
Mon Mar 30, 2015 7:24 pm
Looks like you need new floor pans too.
Mon Mar 30, 2015 7:25 pm
Images: 11
Thanks
Mon Mar 30, 2015 7:26 pm
thats it, i have that kit on my 76 but was busy didn't have time to look up where i got it. I had to go swap out some of the bolts as they wouldn't fit on mine.. not a biggie but worth knowing it might be the case for others.
Mon Mar 30, 2015 10:51 pm
33,044,449 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
