Register •
FAQ
• Login
It is currently Fri Nov 22, 2024 9:58 pm
[ 6 posts ] |
trei75bronco
Joined: Wed Jan 26, 2011 10:55 pm Posts: 837 Images: 0
Dana 20 seals
Looking for a Dana 30 front output seal for the yoke and the bearing retainer and input seals.
Trei
7209360791
Mon Apr 06, 2015 9:03 am |
Re: Dana 20 seals
I've checked all the parts places and you cant get em. Only place would be BH or other venders.
Mon Apr 06, 2015 5:33 pm |
Re: Dana 20 seals
Seals: Input shaft seal (double lip)-CR #517383,Napa #NOS 18676, CR #18676 (good seal) (Do not use Timken #473179) Output shaft seals-Timken #450185 Shift rail seals-CR #6204, Timken #471466 Yoke o-ring-1-1/4"OD x 1-1/8"ID x 1/16". Danco happened to be the brand at the hardware store and it is their #29. Speedi-sleeve for yokes-SKF99155
Bearings: Input- SKF #307NRJ Rear output-Timken #25877 (inner), Timken #15117 (outer) Front output, J shift-Timken #14116 Front output, T shift-Timken #14131
Cups: Rear output-Timken #25821 (inner), Timken #15245 (outer) Front output-Timken #14276 (both T and J)
Shims: 1.20" ID, 1.50" OD
Yoke nuts: 3/4", 16 tpi, top lock
When setting the rear output endplay use a Timken #15118 in the rear position. It is the same size as the #15117 except the inner bore is a couple thousandths larger. This allows you to assemble and disassemble the output shaft without needing a press. Only use it as a setup bearing. Once the correct endplay is set, drop in the #15117 bearing, put the seal on and assemble the shaft.
Mon Apr 06, 2015 8:51 pm |
trei75bronco
Re: Dana 20 seals
Phil there was a small leak at the front output and I was getting a leak between the tcase and tranny. What would I need and are they at Napa?
Wed Apr 08, 2015 7:03 pm |
Re: Dana 20 seals
Wed Apr 08, 2015 11:00 pm |
trei75bronco
Re: Dana 20 seals
I never put a rubber washer on when the front yoke got bent. Guess I will start there i
Fri Apr 10, 2015 5:27 am |
[ 6 posts ] |
Users browsing this forum: No registered users and 28 guests |
