www.ColoradoClassicBroncos.com - View topic - Cooling fans. Coolers. Bronco starter new high torque auto
It is currently Fri Nov 22, 2024 11:30 pm
Reply to topic  [ 15 posts ]
Post Cooling fans. Coolers. Bronco starter new high torque auto
husky 268 pc tool kit in case $75
Hayden cooling fan $30
Hayden cooler 516 model $35
Summit fan sum g4902 Single, 12 in. Diameter, Reversible, 1,107 cfm $50
Derale 13504 plate fin cooler 11x11. $ 50
14" 95lb springs 2.5" coil over. $40
Dana 60 5 lug brake brackets and spacers ford spindle. $40
Cargo plane tie downs $30
Brand new high torque stater for auto ford 302-351 $75
Sat Apr 11, 2015 10:13 pm
Post Re: Cooling fans. Coolers. Bronco starter new high torque au
Interested in the tie downs. How long are they?
Sat Apr 11, 2015 11:14 pm
I'll take the tool set assuming it is complete
Sun Apr 12, 2015 1:17 am
Tool set is complete
The tie downs are about 40" long each
4781 s riveria at
Centennial co 80015.
Be in the garage all day
Sun Apr 12, 2015 6:12 am
Sun Apr 12, 2015 9:01 am
Sun Apr 12, 2015 9:25 am
That's fine
Sun Apr 12, 2015 11:07 am
PayPal is 75bronco7@gmail.com
Mon Apr 13, 2015 7:38 pm
Is any of this stuff still for sale?
I see it all still up on CL too.
Fri May 08, 2015 5:46 pm
any chance those brake brakets will fit on a ford 9
Fri May 08, 2015 9:27 pm
Yes I have the rear leaf spring brackets
Cooling fan
Brackets
No those brackets will not fit a 9"
Diy4x has a bracket use montecarlo calipers and Suzuki sidekick 4 dr rotors
Sat May 09, 2015 8:02 am
What do you want for the rear leaf brackets?
Sat May 09, 2015 1:31 pm
For all 4 100 dollars
Sat May 09, 2015 9:58 pm
Sun May 10, 2015 7:22 am
Sure is
Sun May 10, 2015 5:48 pm
32,961,322 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
