www.ColoradoClassicBroncos.com - View topic - project viperwolfe is starting
It is currently Mon Nov 25, 2024 3:45 am
Reply to topic  [ 550 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9, 10 ... 19  Next
Post Re: project viperwolfe is starting
It would seem easier to have an aluminum shifter stem cut on a lathe, drilled while straight in the lathe, and then bent.
Sat Apr 18, 2015 9:24 pm
Are you planning an "OD" light in the dash somewhere?
Sat Apr 18, 2015 9:29 pm
Sat Apr 18, 2015 9:40 pm
Still playing with the column. I wasn't sure how I would attach the knob to the lever. They fit together pretty sloppy since I cut off the swaged portion for switch clearance. Turns out the diameters are pretty close to the right size for a 5/16" helicoil to go in between. Spent a few hours tapping and dying. Starting to think it would have been easier to make a new lever.
Mon Apr 20, 2015 10:37 pm
A new lever?
Not such a crazy idea after all?
Tue Apr 21, 2015 12:01 am
Got the switch mod done. The helicoil worked good but it took some thinking to install it because the OD of the switch was bigger than the ID of the helicoil. I had to install the switch first then work the helicoil in with the wires going through it. It only took about 40 hours but I'm pretty sure no one else has one like this. Now I just have to fix up that D.
Tue Apr 21, 2015 9:25 pm
That is pure sexy right there!
Wed Apr 22, 2015 5:23 am
Slick idea! I like it.
Wed Apr 22, 2015 8:08 pm
Finally got all the parts to finish this column. Already started on the "working" column in the '74. I thought it had a broken collar but it turns out that was the only thing not broken in it. It seems that 300K miles is rough on parts.
I also rounded up a 3 speed heater switch for the new build.
Tue Apr 28, 2015 10:25 pm
Wed May 06, 2015 2:21 am
I saw one years ago and it took until just a couple months ago to find the application. '64-'66 chevy truck with the thrift heater option. LMC sells the switch/cable but it's about $70. I found this one on ebay for about 1/2 price.
Wed May 06, 2015 3:35 am
Wed May 06, 2015 2:00 pm
Wed May 06, 2015 4:34 pm
Wed May 06, 2015 4:47 pm
Wed May 06, 2015 4:55 pm
It's going slowly but there is some progress occurring. Got the heater rebuilt and modified for the 3 speed fan. Computer is installed. Working on getting the hydroboost installed.
Sun Jun 07, 2015 12:22 am
Got to work on hydroboost fitment today. It went well. Just need to finish the adapter between the HB and the MC, make some hoses, and widen the brake pedal.
Sun Jun 07, 2015 12:27 am
So where does this stand? Any updates?
Fri Aug 21, 2015 12:04 pm
i just finished the motor swap on it last night.
Out with the old
In with the new
Fri Aug 21, 2015 12:34 pm
Good thinking. Now I won't have to worry about that critical new engine startup.
I've been collecting cool parts and will be installing stuff and hopefully starting it up in a couple weeks.
Fri Aug 21, 2015 1:09 pm
Ok boys and girls............
This Sunday, August 30th, we will be wrenching on Phil's rig.
Will get a punch list posted up sometime tomorrow.
If you want to help your welcome to come over as early as 9 am.
I will provide coffee, drinks, and pizza for lunch, etc.
This is a "let's get crap done" kind of affair and all help will be greatly appreciated.
If you need my address just pm me.
Thanks in advance !
Fri Aug 28, 2015 5:14 pm
WTF happened to this? Was it invite only?! No updated pics. Cmon man!!!
Tue Sep 01, 2015 9:58 pm
Wed Sep 02, 2015 12:18 am
Sorry. I guess I was waiting for aforementioned punch list to get posted. I'd be happy to help with anything left if you're going to be working on it again anytime soon. Congrats on the progress.
Wed Sep 02, 2015 12:30 am
Wed Sep 02, 2015 1:08 am
RoxCrusher, 76fordbronco and I hit it hard today. O2 sensors installed. Fuel filler installed, mostly. Put gas in the tank today. Fuel wouldn't pump so tank had to come out. Found fuel lines crossed. Fuel still doesn't pump with any more than a couple psi. Tank needs to come out again after I find a new pump.
Wiring started. Didn't have enough fire to finish it today. Getting close to startup.
Mon Sep 07, 2015 9:35 pm
We have lift-off!
https://youtu.be/OwA2HaDoPH0
https://youtu.be/bpRPFvgzFdI
https://youtu.be/8Rd0vORxXRc
Wed Sep 09, 2015 10:08 pm
Nice!
Wed Sep 09, 2015 10:16 pm
Sounds great. Which cam are you running?
Wed Sep 09, 2015 10:19 pm
Users browsing this forum: Google [Bot] and 70 guests
33,026,130 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
