www.ColoradoClassicBroncos.com - View topic - Someone to weld up my 1-ton steering
It is currently Sat Nov 23, 2024 6:08 pm
Reply to topic  [ 7 posts ]
Post Someone to weld up my 1-ton steering
I picked up the Ruff Stuff 1-ton kit last November on their Black Friday deal. Now that I have the brakes bled, I'm ready to move on to it. I don't have a welder so was wondering if anyone in the club wanted a side-job. Or if anyone wants to recommend someone. Willing to pay as I don't have the expertise or tools to do it right.
I'm sure I can measure everything up but if anyone wants to give pointers, I'd appreciate it. Since my old tie-rods are shot, the Bronco's not drivable right now. I'm thinking it might be a two step process. Get the measurement from knuckle to knuckle with the wheels straight ahead (maybe slightly toe in by 1/8"?) and build that part, then install and measure for the drag link after. Thoughts?
Adam
Tue May 12, 2015 1:26 pm
Post Re: Someone to weld up my 1-ton steering
sounds like you have a plan. You can actually mock up alot of it. If you want (I know its a a little ways) I can weld it it up for you if you can get to the springs. I heart :beer:
Wed May 13, 2015 7:06 am
Cool. I'll get it mocked up and take the measurements. I'll keep you posted. Would love to get this drivable again shortly.
Wed May 13, 2015 7:29 am
What year is you bronco? D44? Year of knuckles? I ask because we built several of these setups a while back and I'm sure we have the measurements you need.
Wed May 13, 2015 10:18 pm
It's a 75 with the 44. I did the F150 knuckles from a 78 or 79. If some one has the measurements, I would appreciate it. Thanks!
Thu May 14, 2015 7:03 am
I've got a tutorial on how to build these that includes measurements that should work for you. Search "heavy duty tie rod". If you can't find it I can track it down when I'm not on my phone.
Thu May 14, 2015 12:37 pm
Found it. I'll go through it and verify measurements.
Thu May 14, 2015 1:40 pm
32,979,511 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
