www.ColoradoClassicBroncos.com - View topic - Rear disc brakes
It is currently Sat Nov 23, 2024 7:46 am
Reply to topic  [ 21 posts ]
 Rear disc brakes
Post Rear disc brakes
I'm kicking around swapping in some Explorer rear discs since it sounds like they're the only swap that has a decent E-brake. I'm also aware that they're set up for the medium bearing rear ends. How hard is it to accurately expand the holes for my big bearing ends?
Sat May 23, 2015 8:25 am
Post Re: Rear disc brakes
Justin, if you do these, I'd love to help/watch. I have all the parts in my garage to do this. Granted, my Bronco has the right rear end for it to be a bolt on. I've heard I might need a spacer though.
Sat May 23, 2015 9:05 am
Can do! Good thoughts, anything else I might need for this?
Sat May 23, 2015 9:06 am
I've seen billet steel "Torino" bearing ends on eBay for $60
Been wondering if changing them would be better than oval shaped holes or welding and drilling or .....
Sat May 23, 2015 10:56 am
The challenge with those is that you need an alignment bar to install them correctly. The long term dream is to build a 9"/14 bolt full float hybrid, so if it isn't easy I'll just stick with drums.
Sat May 23, 2015 11:06 am
I'd say you could just "key hole" the existing bolt holes and you should be good.
Sat May 23, 2015 12:57 pm
How close do the tolerances need to be.?
Sat May 23, 2015 1:02 pm
Justin, if needed, I can loan you a backing plate so you can see what it might need.
Sat May 23, 2015 2:10 pm
I think the lack of enough axle brake offset is going to be the bigger challenge.
Mon May 25, 2015 8:50 pm
So do the brakes need to go out or are longer axles needed?
Mon May 25, 2015 10:52 pm
Tue May 26, 2015 12:04 am
I'm using an axle out of a 77 F150. How much longer do the axles need to be over stock?
Tue May 26, 2015 8:21 am
Tue May 26, 2015 10:20 am
As measured from the axle end to WMS?
Tue May 26, 2015 10:28 am
Tue May 26, 2015 10:56 am
OK, I ate lunch at home and popped a drum off to measure. Looks like you're right. I'm seeing a hair more than 2 3/8 from the backing plate to the face of the axle. If I move forward with this, it looks like all I'll need to do is figure out whether my existing e-brake cables will work and open up the mounting holes. How precisely do those holes need to be cut? It seems like a paper template could be used to mark it and a die grinder used to carefully expand the existing holes.
Tue May 26, 2015 12:40 pm
Use a bearing retainer for your template. You could even tack an old bearing to it to keep it centered.
Tue May 26, 2015 1:37 pm
That's a darn good idea. Thanks!
Tue May 26, 2015 2:00 pm
Over on CB there was a thread about the possibility of 2004-2007 E-150 van rear disc brakes being workable.
Would need at least 16" wheels.
Rotors already 5 on 5.5
Bigger diameter so maybe better parking brake?
Food for thought for the junkyard spotters?
Thu May 28, 2015 6:37 am
Opening the center of a backing plate is pretty easy. I did it on my girlfriends TJ when I put grand Cherokee disks on her jeep. Of course I used a Bridgeport with a boring head. (My dad has one)I'd be happy to take a crack at this since for you but unfortunately it would have to be after June 23rd when I return from my Rubicon trip. I'm in panic mode trying to get everything ready currently.
Fri May 29, 2015 8:34 am
Profile WWW
I just keyholes the holes , center of backing plate was fine, I used explorer parking brake cables. One thing to keep in mind is to clearance the center hole of the rotor, and the axle end. Mine machined 1/16th so they would fit inside the rotors.
Mon Jun 01, 2015 8:50 pm
32,969,511 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
