www.ColoradoClassicBroncos.com - View topic - Manual Transmission
It is currently Sat Nov 23, 2024 7:04 am
Reply to topic  [ 17 posts ]
 Manual Transmission
Post Manual Transmission
Hi Guys,
I'm having some trouble with my 72's shifting. I put a brand new column in and 2nd and 3rd are still difficult to shift into. 3rd more than 2nd. 1st and reverse are perfect. When shifting into third it feels like it's catching on something. I've tired adjusting the adjustment rod to no avail. I replaced the spring and grommets on the levers too.
Any thoughts on why I'm still having trouble?
I'm thinking there must be something wrong either with the clutch or transmission itself - or both. If I do need to change the transmission or clutch I'm thinking I'd like to change it to something that will enable me to cruse easily on the highway. What would you guys recommend? I want to keep the three on the tree.
Thanks,
Danny
Fri May 29, 2015 6:54 pm
Profile WWW
Post Re: Manual Transmission
If it was the clutch it'd be bad for all the gears. Do you know what it feels like when a syncro goes out?
Fri May 29, 2015 7:00 pm
No, what would that feel like?
Thanks,
Danny
Fri May 29, 2015 7:12 pm
Profile WWW
Bushings replaced on shift linkage?
Fri May 29, 2015 9:40 pm
It feels like what you are describing, like it's catching on the gears instead smoothly shifting. Have you ever shifted a manual without a clutch by matching the the engine RPM with the next shift? Try this, but use the clutch, and if it shifts easier then I'd say you may have a syncro problem.
Sat May 30, 2015 5:28 am
Trel - yes I have replaced all the bushings between the pedal and trans and also on the column.
Thanks, Kinder. I have shifted like that - once - on a superbeetle I used to own when the clutch cable broke. Wasn't fun but go me home. I think you've hit the nail on the head. Are these transmissions difficult to rebuild? Would you advice putting a new clutch in too while the trans is out?
Thanks,
Danny
Sat May 30, 2015 7:41 am
Profile WWW
They're cheap enough you could just buy another used and not worry about it for another 10 years. And by cheap I mean most times you can find them free.
Sat May 30, 2015 8:47 am
That's good advice, Frank. Thanks. I just put an add in the wanted section. Would you recommend putting in a new clutch while changing the trans?
Thanks,
Danny
Sat May 30, 2015 10:18 am
Profile WWW
Cheap enough and good insurance to make sure you're not back in there a few months from now.
Sat May 30, 2015 10:21 am
It just so happens, I pulled mine out today. if you want it come and get it. (worked great as of 10 AM this morning)
Sat May 30, 2015 11:20 pm
Sun May 31, 2015 9:21 am
Danny, I would not feel slighted at all if you went with the closer and already available option of D&D72.
Sun May 31, 2015 9:24 am
Thanks, Frank. I'm going to pick up John's on Wednesday.
Thank you again, everyone for all the kind offers to help me. I appreciate!
Thanks,
Danny
Sun May 31, 2015 9:43 pm
Profile WWW
Yeah Thanks Frank! Zack, Zachary, whatever.... icon biggin
Mon Jun 01, 2015 9:40 am
Dude.
Mon Jun 01, 2015 9:43 am
Thanks again, John for the transmission. I appreciate it!
Zack, thanks again for the offer! Hope your'e having a good time in NC.
Thanks,
Danny
Thu Jun 04, 2015 8:12 am
Profile WWW
Glad to help. Dont forget to fill it up even though I didnt drain it.
Thu Jun 04, 2015 8:32 pm
32,968,737 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
