www.ColoradoClassicBroncos.com - View topic - Remove pitman arm
It is currently Sat Nov 23, 2024 7:20 am
Reply to topic  [ 18 posts ]
 Remove pitman arm
Post Remove pitman arm
OK, I don't think it should be this hard but how do you get the pitman arm puller on? My frame seems to be in the way. Do you need to loosen the box from the frame?
Adam
Sat Jun 06, 2015 3:18 pm
Post Re: Remove pitman arm
Unless you have a odd puller it usually clears the frame, the usual problem is getting the tool onto the large pitman arm that the broncos use.
Sat Jun 06, 2015 6:14 pm
Here is a picture of the puller.
And here is the pitman arm:
The last pic is deceptive due to be head on.
Adam
Sat Jun 06, 2015 6:38 pm
Yikes, that pitman arm is on there deep! Looks like you'll have to pull the box. Most don't go on that far. Or you have a non-stock steering box or pitman arm.
Sat Jun 06, 2015 8:03 pm
I'm pretty sure it's all stock. I've never changed it in the 20+ years I've owned it and it was completely stock when I got it.
I was going to pull it so I could drill it out for my one ton steering. I was looking at it and I'm not sure there is enough material to put a 1" hole in it. I have the insert from RuffStuff.
Guess I know what I'm doing tomorrow. :-)
I should have expected something like this. Nothing is ever easy. Just need to get this hole done to reassemble and drive it.
Sat Jun 06, 2015 9:24 pm
1 whack downward with my BFH and that...was that!
No puller necessary!
Sun Jun 07, 2015 12:09 am
I had one that heat or a 20 ton press wouldn't remove, until both were combined resulting in one big bang.
Sun Jun 07, 2015 12:32 am
Ugh, I hope it doesn't come to that. I don't have either heat or a press. I see this becoming project Downward Spiral. Next up steering box rebuild. :-)
Sun Jun 07, 2015 8:12 am
Sun Jun 07, 2015 11:49 am
At some point. I needed new tie rods and I got the one ton setup for less than replacing the stock ones. Still rocking 33" tires and not really trying to get that aggressive yet. Kids are still small so mostly easier trails for now. Just trying to do things once as needed.
Sun Jun 07, 2015 11:57 am
Thanks to plumbdoctor for letting me swing by and get Landshark's reamer, I got things back together today. The reamer made semi-short work of the pitman arm while still on the Bronco. I realized though that I left the tube on the drag link about an inch too long so I have zero adjust right now. Oh well. Worse case there, I'm out a bung. I need to set the toe and it should be good to go. I realized I should probably re-bleed the brakes one last time. The pedal just isn't quite where I want it on the first stab.
For those who have done the RuffStuff kit, are you running a steering stabilizer? I can't see how it would work without going to a shorter shock than stock. Unless I have my dragline on 180 backwards. :)
Oh, and just to show it truly is project Downward Spiral, I pulled it into the garage after the test drive around the block and found fuel dripping from the fuel pump. Can't tell if it is from the fuel pump or where the hard line that goes to the carb connects yet. That will be tomorrow's project.
Anyways, thanks to all who have chimed in on this project!
Adam
Sat Jun 13, 2015 4:17 pm
I've never run a stabilizer on mine. Had a finger or two whacked by the wheel with the manual box, but power steering and smarter driving took care of that.
Sat Jun 13, 2015 4:58 pm
No stabilizer for me either. I don't miss it.
Sat Jun 13, 2015 8:07 pm
I use a stock stabilizer with the ruff stuff. Can't fit a bigger one in because the winch is in the way. I had to make a bracket for the drag link. Just used a piece of 3x3 angle and some u-bolts.
Sat Jun 13, 2015 8:41 pm
Sat Jun 13, 2015 8:59 pm
Sun Jun 14, 2015 2:14 am
Thanks. I'll flip it and see. Makes more sense that way but they describe the end I have at the pitman arm currently as correct.
Sun Jun 14, 2015 8:24 am
If I remember correctly one of those has a longer range of useable movement to account for axle travel. You might double check that before you swap ends. My drag link has 2 ends that look like the one attached to the pitman arm.
Sun Jun 14, 2015 1:18 pm
32,969,039 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
