It is currently Sun Nov 24, 2024 6:24 am
Digger's '69 Build Thread
Re: New Member 69
Mon Jun 15, 2015 7:42 pm |
Re: New Member 69
You just need taller tires.
Mon Jun 15, 2015 10:05 pm |
Re: New Member 69
Mon Jun 15, 2015 10:24 pm |
Re: New Member 69
My plan from the beginning was to make the Bronco our family adventure rig. Part of that plan involves towing our small popup camper, for which I needed a hitch. Weighing a lot of options, I settled on the Tom's receiver hitch. It wasn't the cheapest, but it gets the job done and saves me more fabrication time. by , on Flickr
The only things I don't like about the Tom's hitch is the way the receiver tube is welded in the middle of the cross tube and lack of any actual Class III certification.
I had to re-drill the holes in my gas tank brackets and slot the frame holes slightly rearward to clear the 23 gal fuel tank. (not a Tom's tank) by , on Flickr
I also had to notch the PO's rear bumper to clear the hitch, but it fits well. The new bumper will clear without issue. by , on Flickr
Tue Jul 21, 2015 9:00 pm |
Re: New Member 69
A bronco with a trailer brings tears of joy to my eyes!
Tue Jul 21, 2015 9:04 pm |
Re: New Member 69
I also needed some side mirrors since mine were removed and 'glassed over by the PO.
I bought some 1stGen Ranger/BII mirrors from Dorman. They gave the Bronco a little bit more modern look.
I had to contour them slightly to match the curve of the door. by , on Flickr
New Rivnuts in the door. by , on Flickr
by , on Flickr
by , on Flickr
Re: New Member 69
Now for the big job!
I have been unable to take the kids anywhere due to lack of rear seat. I ordered a Tom's fold-n-tumble, but refused to install it until I had proper roll over protection. The Bronco came with a simple roll bar tied to the floor. I didn't trust it much. I needed a full six-point cage and wanted to do something a little different with the front legs. My plan was to build a cage modeled after the Rock Hard Sport cages used on Jeep JKs to free up space in the foot box and tie the cage to the firewall to add rigidity to the body. I also will tie the cage through the floor to the frame for strength.
Using what I modeled before in CAD I hashed out an idea and polished it up it bit using computer analysis.
The first part was laying out the legs and making sure they would fit between the dash and inner wall of the tub. by , on Flickr
by , on Flickr
by , on Flickr
Tue Jul 21, 2015 9:23 pm |
Re: New Member 69
I had a whole weekend without the family, so I took 2 extra days off to bang out this project. This was Saturday morning at 6:30am. by , on Flickr
Time to start yanking parts! by , on Flickr
by , on Flickr
by , on Flickr
Tue Jul 21, 2015 9:27 pm |
Re: New Member 69
I like knowing where my tube came from: by , on Flickr
A side view of the front legs. by , on Flickr
Bending some tube. I was going to build this in two pieces, but decided to try the whole thing in one shot. by , on Flickr
Mocking up the main hoop and side hoops took the longest since it was laying the foundation for the rest of the work. by , on Flickr
Figuring out the front interface. by , on Flickr
by , on Flickr
End of day 1 (T=15hrs) by , on Flickr
Tue Jul 21, 2015 9:32 pm |
Re: New Member 69
I spent Sunday tacking together pieces and adding more body tie-in points to each leg. I also started laying out the rear halo and diagonal supports. by , on Flickr
Since I can't put diagonal bracing in the B-pillar hoop, I came up with a plan to form a large "X" from the back corners to the front corners to triangulate the cage.
Using CAD to determine tube lengths and cope angles, the pieces fit together nicely. by , on Flickr
by , on Flickr
Day two ended with all the tubes installed and tacked into place. (T=30hrs) by , on Flickr
Tue Jul 21, 2015 9:38 pm |
Re: New Member 69
I woke up Monday and took one more picture in the daylight by , on Flickr
Monday I needed to add all the necessary brackets for 3-point seatbelts and windshield supports along with corner gussets. I build out triangulated brackets to hold the windshield, taking care to make sure the frame was parallel with the doors. by , on Flickr
by , on Flickr
With everything in place, my neighbor helped me pull the cage to finish welding the tubes and brackets together. by , on Flickr
Here you can see the longitudinal and lateral braces for the front legs. I tied into the strongest points on the body. Now the cage ties the rear of the body to the front and should add much rigidity to the truck. Even without these brackets, the front legs are pinned in by the dash and door supports and the fit is tight. by , on Flickr
Day 3 (T=42hrs)
Tue Jul 21, 2015 9:47 pm |
Re: New Member 69
Tuesday I got to work early to beat the rain. It was time for some paint! by , on Flickr by , on Flickr by , on Flickr After waiting a few hours, time to install! by , on Flickr The welds came out pretty good. by , on Flickr by , on Flickr by , on Flickr by , on Flickr I didn't take many pictures, but I got the Tom's Fold-n-Tumble seat installed along with the 3-point seat belts. by , on Flickr by , on Flickr The fit with the soft top came out perfect. I maximized the room inside without interfering with anything important. by , on Flickr by , on Flickr by , on Flickr Total time = 54 hrs.
Tue Jul 21, 2015 9:54 pm |
Re: New Member 69
Dang. That is nice! Love the front legs.
Tue Jul 21, 2015 10:02 pm |
Re: New Member 69
Wed Jul 22, 2015 12:05 am |
Re: New Member 69
Love the cage. when are you tying it into the frame?
Wed Jul 22, 2015 6:53 am |
TOOLMAN
Re: New Member 69
Wed Jul 22, 2015 7:03 am |
Re: New Member 69
Very nicely done! I really like the look. kids will enjoy the first ride!!
Wed Jul 22, 2015 7:05 am |
Re: New Member 69
Very nice.
Wed Jul 22, 2015 8:16 am |
Dukietown
Re: New Member 69
soooo when can I drop mine off to get a cage built/installed? Looks great!
Wed Jul 22, 2015 8:57 am |
Re: New Member 69
Wed Jul 22, 2015 3:52 pm |
Re: New Member 69
More build, more pictures. Rear bumper this time:
by , on Flickr
by , on Flickr
by , on Flickr
by , on Flickr
by , on Flickr
by , on Flickr
by , on Flickr
by , on Flickr
by , on Flickr
Sun Aug 23, 2015 8:46 pm |
Re: New Member 69
Testing out fit with the camper. She's a bit tight, but still has enough clearance. I was ready to replace the lift jack if necessary. Even went through some dips without issue.
by , on Flickr
by , on Flickr
Sun Aug 23, 2015 9:00 pm |
Re: New Member 69
And for my last-minute, midnight-buzzer-beater job, I threw together a storage box to lock up the tools. Not Fort Knox, but will deter the opportunist.
by , on Flickr
by , on Flickr
by , on Flickr
by , on Flickr
by , on Flickr
by , on Flickr
Sun Aug 23, 2015 9:03 pm |
Colorado75bronc
Re: New Member 69
Looks great! I like the box!
Sent from my SAMSUNG-SM-G890A using Tapatalk
Sun Aug 23, 2015 10:22 pm |
Dirtheadz
Re: New Member 69
box looks cool.... think Ive seen similar somewhere before
Mon Aug 24, 2015 7:31 am |
Re: New Member 69
Mon Aug 24, 2015 8:33 pm |
B.O.B.
Re: New Member 69
What size plate did you use on the front of the cage?
Tue Aug 25, 2015 9:24 pm |
Re: New Member 69
Wed Aug 26, 2015 9:07 am |
Re: New Member 69
Mon Nov 09, 2015 8:37 pm |
Re: New Member 69
Much better. Looks great!
Mon Nov 09, 2015 8:39 pm |
