www.ColoradoClassicBroncos.com - View topic - Lost brake fluid
It is currently Sat Nov 23, 2024 4:03 pm
Reply to topic  [ 15 posts ]
 Lost brake fluid
Post Lost brake fluid
So brakes got a little spongee and looked at fluid on the big compartment is almost dry. I take it that the big one is for the front. Looked around and nothing is leaking. Any thoughts?
Wed Jul 22, 2015 9:54 pm
Post Re: Lost brake fluid
Fill it up, bleed and then see if you can find some-way of putting pressure on the pedal while you look. A scissor jack off the seat can work. Got to have a leak somewhere.
Thu Jul 23, 2015 2:34 am
Or the pads/shoes are worn down to almost nothing.
Thu Jul 23, 2015 2:49 am
Disc or Drum fronts?
Thu Jul 23, 2015 7:05 am
fluid has to go somewhere... leak or worn pads/ shoes.
Thu Jul 23, 2015 7:35 am
Could also be a slow leak from the rear drum cylinders.
Thu Jul 23, 2015 9:48 am
did the wire harness fall off the MC?
icon biggin
Thu Jul 23, 2015 1:08 pm
I think when the ecu fried it burned up my fluid
Thu Jul 23, 2015 8:20 pm
Don't let the smoke out of your wiring. It's really hard to put back in.
Thu Jul 23, 2015 10:09 pm
My Master Cylinder leaks from the cap. When it does it drips onto the header/exaust and burns off instantly. Just a thought.
TJ
F. Scott Fitzgerald
Fri Jul 24, 2015 5:46 am
Yeah, I've had the same not that you mention it. The wire clip on top was a little loose, so I took a hammer and hit the wire between the two bowls to take the slack out and that stopped the leaking.
Fri Jul 24, 2015 6:06 am
I fixed mine by putting a piece of rubber hose around the wire.
TJ
F. Scott Fitzgerald
Sat Jul 25, 2015 5:46 pm
Wed Jul 29, 2015 6:29 am
Wed Jul 29, 2015 7:19 am
You betta believe it!
Wed Aug 05, 2015 5:08 am
32,975,885 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
