www.ColoradoClassicBroncos.com - View topic - free bronco treasures
It is currently Fri Nov 22, 2024 1:21 am
Reply to topic  [ 19 posts ]
Post free bronco treasures
I finally consolidated all the spare stuff I had stashed in the crawl space so here's the list.
1) Spindles, backing plates, hub and drums (11"x 2"), hardware and shoes off a front 44. (GONE)
2) Stock front coils (GONE) and rear leaf pack w/ urethane bushings (5 leaves with long add-a-leaf or overload on bottom). (REAR LEAVES GONE)
3) Stock radiator for std trans. (no cooler) No leaks when pulled, I replaced it with a new on with cooler when I did the C4 conversion. (GONE)
4) Stock "Armstrong" steering gear box with stock pitman arm. (GONE)
5) 4* urethane C bushings in good shape.
6) Std trans starter that worked well when replaced with auto starter. (GONE)
7) Splash shield, (GONE) bell housing, (GONE) flywheel, (GONE) clutch, pressure plate, RAT 3 speed trans (needs syncro in 1st gear)(GONE), and a 3 speed to Dana 20 adapter. (GONE)
8) Clutch pedal w/linkage and motor bracket. (GONE)
9) Hurst 3 speed floor shifter with linkage and a metal tunnel cover.
10) Old school fiberglass rear flares. (GONE)
I can bring any or all of this to the breakfast at Rudy's on Saturday if anyone wants any of it.
Mark.
Sun Sep 13, 2015 9:47 pm
Post Re: free bronco treasures
I'd take the front d44 parts and the 3 speed.
Sun Sep 13, 2015 9:49 pm
I would be interested in the steering box/ pitman arm & radiator. I'll be at the breakfast!
Sun Sep 13, 2015 9:55 pm
Sun Sep 13, 2015 10:07 pm
Sun Sep 13, 2015 10:09 pm
I'm interested in fiberglass flares if they are intact. I can't make the breakfast but maybe someone could bring them north?
Sun Sep 13, 2015 10:10 pm
Not sure yet, can make other arrangements if not.
Sun Sep 13, 2015 10:16 pm
Sun Sep 13, 2015 10:24 pm
Sun Sep 13, 2015 10:30 pm
I would like the radiator, I'll be at the breakfast. THANKS!!!
Mon Sep 14, 2015 5:46 am
Mon Sep 14, 2015 6:11 am
Mon Sep 14, 2015 6:23 am
Mon Sep 14, 2015 7:25 am
I'll take the splash shield, flywheel and bellhousing and manual starter
Sent from my SAMSUNG-SM-G890A using Tapatalk
Mon Sep 14, 2015 5:59 pm
Oh and pedal assembly and mount
Tue Sep 15, 2015 6:03 am
Tue Sep 15, 2015 6:06 am
Give them to Ben aka. Dirtheadz if you wouldn't mind, I have to work unfortunately. Thank you very much, I'm getting ready to complete a manual swap from an auto for a friend and need all the manual parts I can get. I appreciate it very much.
Tue Sep 15, 2015 10:31 pm
Wed Sep 16, 2015 7:04 am
32,936,861 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
