www.ColoradoClassicBroncos.com - View topic - Clutch rod hole
It is currently Sat Nov 23, 2024 11:44 am
Reply to topic  [ 11 posts ]
 Clutch rod hole
Post Clutch rod hole
Anyone know how big the hole in the floor board for the clutch rod is? The rubber grommet on mine came out in pieces. I'm replacing that panel as part of the rust repairs. I think it is 1.25" but it could be 1 1/8".
I was going to call the Bronco Hut but got too busy at work.
Second question, what's the best way to cut said hole?
Fri Sep 18, 2015 5:41 pm
Post Re: Clutch rod hole
No idea what the official number is, but id just use whatever makes the grommet fit and give adequate room.
Fri Sep 18, 2015 6:33 pm
I don't have the replacement grommet yet. I want to get the floors in this weekend. Work is going to have me traveling a ton starting in a week. I guess I could go 1 1/8 and be OK. I have it centered where it needs to be so I'm probably good. Just easier to cut the hole while the panel is out.
Fri Sep 18, 2015 7:54 pm
Since the top side is sealed with bed liner I measured the bottom. Not the easiest place to get a good measurement but it looks like 1-1/4" on mine.
Fri Sep 18, 2015 8:47 pm
Thanks! I'm guessing a hole saw is my best friend here?
Fri Sep 18, 2015 8:51 pm
That is the only way I would get a round hole unless you have a step bit that big.
Fri Sep 18, 2015 8:57 pm
Yep, my step only goes to 7/8. Home Depot here I come!
Fri Sep 18, 2015 8:58 pm
Fri Sep 18, 2015 9:10 pm
Just checked the project bronco 1 3/8. I used a hole saw on the 1/2 cab floor replacement. But I think it was to big for my rod boot. 1 1/4 might be better.
Sat Sep 19, 2015 6:37 am
Thanks. HD is only a few miles from my house. If they don't have one I'll make the trip to HF. Just want to make sure the grommet will fit.
Sat Sep 19, 2015 7:34 am
I have an original slug out of my 72 (believe it or not) it measures at 1 3/8"
Sun Sep 20, 2015 11:17 am
32,972,945 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
