It is currently Mon Nov 25, 2024 5:34 am
project viperwolfe is starting
D&D72
Re: project viperwolfe is starting
what glass is still needed?
Mon Oct 05, 2015 6:07 pm |
Not really the style I'm looking for but thanks. Here are some I like. The first one is a 16" dodge van wheel. I'm hoping to find something in here with at least 4 1/2" of backspacing. Untitled.jpg Untitled3.jpg Untitled5.jpg
Mon Oct 05, 2015 9:21 pm |
Mon Oct 05, 2015 9:22 pm |
I believe I have all the glass for hard top if you want it, Also I will be happy to toss in for a brand new windshield
I do have patterns for all the glass, if you can not find the other door and wings, let me know. I will see what I can do
Tue Oct 06, 2015 3:49 am |
I also have a full set of hardtop glass.
Tue Oct 06, 2015 10:08 am |
No hardtop.
Tue Oct 06, 2015 2:06 pm |
Well I happen to have a hard top too!
Tue Oct 06, 2015 8:18 pm |
Hardtop rear post bolt holes are welded up.
Wed Oct 07, 2015 12:22 am |
Finishing up the D44 setup. I didn't have a good tool to hold the yoke so I made one. I also found my twinstick knobs. 20151006_185803.jpg 20151006_195237.jpg 20151006_164850.jpg
Wed Oct 07, 2015 1:07 am |
I think these are the ones you're looking for... Too bad they don't come with center caps or beauty rings !
It cost me about $20 per wheel to have the centers milled an eighth of an inch all the way around for hub clearance.
Wed Oct 07, 2015 10:40 pm |
D44 is good to go. Just need to refurb knuckles and find a good spindle. 20151008_182150.jpg
Fri Oct 09, 2015 12:20 am |
What paint did you use on there?
Fri Oct 09, 2015 12:45 am |
Broncobsession
What spindle you need? I think I have a spare 5-bolt 76/77 spindle and caliper bracket/dust shield. Would just need to find it. Or you talking 6-bolt chevy spindle? Or stock ford drum spindle?
Fri Oct 09, 2015 7:20 pm |
Fri Oct 09, 2015 8:05 pm |
Fri Oct 09, 2015 8:07 pm |
plumbdoctor
I guess it's Moab Mike now...and Rox, I had pm'ed Phil about a grill or grill parts a while back...I have one that needs some minor tweaking....still needed or????
Fri Oct 09, 2015 9:42 pm |
Sat Oct 10, 2015 7:25 am |
SAVE THE DATE: week of November 23rd.
it looks like the next work party will be during the week of Thanksgiving holiday.
I have taken that week off and plan to focus on project viper wolf, other than bird day itself.
- replace front axle assembly - re-gear the rear end - mount and fit doors, fenders, grill, tailgate - body work and primer
Please post up if you can come play
Sat Oct 10, 2015 7:46 am |
Not sure what that weekend will look like, but I'm hoping to make it.
Sat Oct 10, 2015 7:58 am |
I'll be coming up Friday and staying until the bodywork is done.
Sat Oct 10, 2015 8:05 am |
Sat Oct 10, 2015 1:27 pm |
Broncobsession
I found the spindle Phil. Little dusty. PM your mailing address and I will get it out to you.
Sun Oct 11, 2015 6:52 pm |
Plan to help for at least a day most likely a couple.
Wed Oct 14, 2015 10:31 pm |
I'll stop by and lend a hand after work.
Sun Oct 18, 2015 1:52 pm |
Wed Oct 21, 2015 3:36 am |
Post up a pic of the window tray, I likely have one. Also I'm fairly certain I have the bolts & screws needed, but they are in the container of broncos past, someone skilled in digging will need to come by & search.
Wed Oct 21, 2015 8:34 am |
BroncoRaider
I'm available for a couple of days. Let me know place & time.
-Tim
Fri Oct 30, 2015 10:40 am |
Fri Oct 30, 2015 2:45 pm |
Im planning to come by and BS with everyone.
Sat Oct 31, 2015 7:23 am |
If in town I will swing by.
Sat Oct 31, 2015 10:36 am |
Users browsing this forum: No registered users and 48 guests |
