It is currently Thu Nov 21, 2024 1:46 pm
JGZ
Re: ZOSO's toys
Nice.How much better do the edlebrocks flow? Just starting out with this so I don't really have a game plan yet.
Mon Nov 02, 2015 5:07 pm |
Re: ZOSO's toys
And the horsepower war has officially been declared! I think I saw a spare turbo around here somewhere...
Mon Nov 02, 2015 10:42 pm |
Re: ZOSO's toys
Tue Nov 03, 2015 1:34 pm |
Re: ZOSO's toys
Tue Nov 03, 2015 2:03 pm |
Re: ZOSO's toys
Ready to pull it out. Possibly thursday I'll pull it and get it on the stand.
Mon Nov 23, 2015 5:14 pm |
Re: ZOSO's toys
Digging that aluminum foil on the fuel line.
Mon Nov 23, 2015 7:14 pm |
Re: ZOSO's toys
It helped. It's a sleeve. Along with the carb spacer and rerouting the fuel lines.
Mon Nov 23, 2015 7:29 pm |
Re: ZOSO's toys
I have started the mockup of the hydroboost and bracket. I plan to make the brake lines and get everything ready then remove it all until the engine is back in. With this offset bracket it sure is long. Also started the tear down of the engine. I think I got pretty lucky. Doesnt look like the piston is hurt. there is a mark on it from the valve but doesnt looked cracked. So i'll clean the carbon off and on some new heads.
Fri Dec 04, 2015 7:54 am |
Re: ZOSO's toys
I couldn't help but mock some things up. Will be sand blasting the brackets to give a nice finish. Will Paint the upper also.
Sat Dec 05, 2015 8:55 am |
Re: ZOSO's toys
Was very surprised today. I pulled the interior and carpet. I found a lot less rust than I expected. Looks like a small patch is required at the seat bolt holes on the passenger side. and maybe a full drivers pan since it's been patched once.
Fri Dec 11, 2015 7:17 pm |
Re: ZOSO's toys
How in gods name has that horn ring stayed intact for all of these years?
Fri Dec 11, 2015 11:14 pm |
Re: ZOSO's toys
Rob prefers to use his middle digit for signaling his fury.
Fri Dec 11, 2015 11:25 pm |
Re: ZOSO's toys
Sat Dec 12, 2015 8:58 am |
Re: ZOSO's toys
Spent the day in the garage. Got the 1" body lift installed. Also built new brake lines from the master to distribution block. don't like how one turned out so I'll be redoing that one. Started moving the arb compressor over to the drivers side inner fender.
I need to hit a junk yard for an ecu box so I can get that cut in while the engine is out.
Trans kit should be here soon so I can start on that.
Fri Jan 01, 2016 10:07 pm |
Re: ZOSO's toys
trans kit showed up. Has a new roller clutch in the kit. Will possibly sell the shift correction kit and get a sure cure kit.
Wed Jan 06, 2016 7:01 pm |
Re: ZOSO's toys
The original body bushings had seen better days.
Going to be a tight fit with everything crammed under hood again.
Hey Garry you ready to build some adaptors? Looks like it would fit awesome.
Wed Jan 06, 2016 7:11 pm |
Re: ZOSO's toys
is that a compressor next to the hydroboost? can you move it? maybe under the bronco?
Wed Jan 06, 2016 11:45 pm |
Re: ZOSO's toys
Thu Jan 07, 2016 7:01 am |
EFI Guy
Re: ZOSO's toys
Thu Jan 07, 2016 9:40 pm |
Re: ZOSO's toys
You realize this is no longer optional, right?
Fri Jan 08, 2016 12:09 am |
Re: ZOSO's toys
Fri Jan 08, 2016 6:58 am |
Re: ZOSO's toys
....is coming to my house?
Fri Jan 08, 2016 7:52 am |
Re: ZOSO's toys
Fri Jan 08, 2016 10:03 am |
Re: ZOSO's toys
Fri Jan 08, 2016 2:38 pm |
EFI Guy
Re: ZOSO's toys
Fri Jan 08, 2016 9:21 pm |
Re: ZOSO's toys
Fri Jan 08, 2016 9:46 pm |
Re: ZOSO's toys
Sat Jan 09, 2016 12:44 am |
Re: ZOSO's toys
Wonder if I could get that piped into my 400
Sun Jan 10, 2016 11:49 am |
Re: ZOSO's toys
Mon Jan 11, 2016 2:45 am |
Re: ZOSO's toys
Still gathering parts. I ordered the new reverse drum and mechanical diode and sure cure kit for the 4r70w. Also ordered the 98 n up case connector. Once those arrive I can finally make some progress and get this trans rebuilt.
Tue Feb 09, 2016 7:35 pm |
Users browsing this forum: No registered users and 15 guests |
