It is currently Sat Nov 23, 2024 10:57 pm
[ 13 posts ] |
Core support bracket
Anyone have one or two of these laying around: http://shop.broncograveyard.com/66-77-B ... fo/14008S/? I'm hoping that someone who tubed their front clip has one.
Mon Nov 30, 2015 12:25 am |
Re: Core support bracket
I'll look and see. My core support is still in the scrap pile at work.
Mon Nov 30, 2015 12:47 am |
If they're still there all 3 would be appreciated. I need at least one for a second battery on the drivers side. The vertical parts are what I need.
Mon Nov 30, 2015 12:51 am |
The Project X tub will soon be headed to the recyclers. I can cut these off before it goes.
Mon Nov 30, 2015 7:27 am |
How is the core support on project x? if its not too much trouble i would love to have a section of it from the center to the driver side, i will need a section in there to patch a rot area on mine eventually.
Mon Nov 30, 2015 9:57 am |
Mon Nov 30, 2015 10:18 am |
Mine are hammered sh*t. You don't want them.
Mon Nov 30, 2015 12:58 pm |
Mon Nov 30, 2015 3:37 pm |
Mon Nov 30, 2015 3:38 pm |
plumbdoctor
Chris, I have a half section here already cut if you want it....justin, I have some of the verticals here, and Zack, if the whole core support is good I would like it, also need inner wheel wells if they are good....lets talk swap
Mon Nov 30, 2015 8:39 pm |
Sweet, thanks!
Mon Nov 30, 2015 8:40 pm |
Mon Nov 30, 2015 10:03 pm |
Great thanks.
Tue Dec 01, 2015 12:20 am |
[ 13 posts ] |
