It is currently Sat Nov 23, 2024 5:18 am
Re: 351 EFI build discussion
Wed Dec 30, 2015 3:31 pm |
JGZ
Who's engine is it?
Wed Dec 30, 2015 3:42 pm |
Wed Dec 30, 2015 4:12 pm |
Wed Dec 30, 2015 10:17 pm |
JGZ
How you like those afr's
Wed Dec 30, 2015 10:19 pm |
Thu Dec 31, 2015 12:34 am |
JGZ
Thu Dec 31, 2015 1:44 pm |
Thu Dec 31, 2015 2:07 pm |
JGZ
If you had your choice,would you run the 185' s over the 165's on the 351?[/quote]
Probably not with the current setup.[/quote] Care to expand on that?
Thu Dec 31, 2015 2:14 pm |
The engine was built to maximize low end torque. The 165's would help there and would also add some to upper range horsepower. I think the 185's would take away some from the low end.
Thu Dec 31, 2015 3:12 pm |
Thu Dec 31, 2015 8:18 pm |
JGZ
Let me know what they tell you ZOSO.
Thu Dec 31, 2015 9:30 pm |
Mon Jan 04, 2016 12:29 pm |
Holiday hang up, hope to be picking it up soon, if it's good I'll post up.
Tue Jan 05, 2016 10:07 am |
Wed Jan 06, 2016 6:59 pm |
Dropped mine off at MPG today.
He said to expect it back at the end of February.
Gives me some time to get harness going.
Thu Jan 07, 2016 3:36 pm |
Picked mine up today.
I would highly recommend getting a detailed written estimate before authorizing the work.
Fri Feb 19, 2016 7:25 pm |
Fri Feb 19, 2016 8:42 pm |
Yikes, I don't want to hear that. I hope to be grabbing TGB's soon and though it was a different builder I hope that I have a good experience.
Fri Feb 19, 2016 9:15 pm |
Yeah, what Scott talked about on the phone and what his written estimate came out to was fairly different. I'm sure he's a good technician, but I haven't been impressed with his people skills.
Fri Feb 19, 2016 9:31 pm |
I will say he was very off putting at first, but I was adamant to discuss cost on every decision phone call and my final bill was in line with the notes I kept. He was also very patient with me and was helpful.
Not to say my experience was flawless as there were a couple times that he said he'd be there for me to drop something off and then wouldn't be. Overall, I think he does good work but could use some business acumen for sure.
Fri Feb 19, 2016 9:44 pm |
I called today about some head work on my 460 I'm building. Sounded good on the phone but was booked out until the end of April. I'll be using another machine shop he recommended. Even they're 3-4 weeks out for simple head work but I liked them at least as much on the phone as I liked mpg.
Fri Feb 19, 2016 10:25 pm |
He's planning to have my block till April as well. Not a big deal as I plan to drive my rig all summer then do the swap and EFI.
Fri Feb 19, 2016 10:53 pm |
Fri Feb 19, 2016 10:55 pm |
He's slow, but progress continues.
Fri Feb 19, 2016 10:56 pm |
I don't think he was trying to pull a fast one.......I just think his lack of appreciation for details was the culprit.
Still, I was expecting a price lower than the "on the high end" price we talked about. Glad I had an extra 700 bones laying around.
The good thing is that we ended up at 9.4:1 for compression ratio.
Sat Feb 20, 2016 6:03 am |
Sweet! What heads are you running?
Sat Feb 20, 2016 9:02 am |
Sat Feb 20, 2016 9:20 am |
Ouch. I though about having my gt40s milled, but not for that price. I'd go stroker first.
Sat Feb 20, 2016 9:22 am |
To be fair about it.......there was 75 +/- to remove and heli-coil a broken bolt in one of the heads
Sat Feb 20, 2016 1:02 pm |
Users browsing this forum: Google [Bot] and 17 guests |
