www.ColoradoClassicBroncos.com - View topic - 69 Dudes-- Just the beginning
It is currently Thu Nov 21, 2024 4:48 pm
Reply to topic  [ 405 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9, 10 ... 14  Next
Post Re: 69 Dudes-- Just the beginning
Nice!
Sat Jan 23, 2016 6:04 pm
Nice!
It will be much easier to plumb that master cylinder with that out of the way! LOL.
Sat Jan 23, 2016 6:38 pm
You know, while you're in there.... Bronco creep at its finest!
Sat Jan 23, 2016 9:09 pm
Trying to figure out the installation of this BCB flexible hydraulic line in my slave cylinder. Here is what I'm working with. Anybody have any suggestions/ideas/thoughts? I tried just pressing it in, and it wasn't moving at all.
Mon Feb 15, 2016 11:43 am
Post 69 Dudes-- Just the beginning
Are the line and the slave part of the same kit? The collar goes on the line, with the O ring towards the slave, then it is a press in deal.
Edit: Right off the end of that line doesn't look like the correct size from your picture.
Mon Feb 15, 2016 11:51 am
This video has some good pointers
http://youtu.be/RVjEMoroZQM
Mon Feb 15, 2016 11:56 am
Mon Feb 15, 2016 12:17 pm
I'm in the same boat it looks like. I just pulled my store bought slave cylinder out of the box & my BCB hose and they don't look compatible. WTF.
Mon Feb 15, 2016 1:16 pm
Mon Feb 15, 2016 1:36 pm
I just looked at every slave cylinder Rock Auto offers for a 94 F250 5.8l, and they all have the same fittings as our slave cylinders. I don't see how the BCB hose would fit. Unless BCB is using a slave cylinder from a different application. I'd as what the application is, and buy it elsewhere.
Their hose for aftermarket master cylinder, has a different slave cylinder end on it.
Mon Feb 15, 2016 1:54 pm
So I think I solved our problem Chad. The quick connect fitting has a roll pin holding it in. I tapped that out and found that it has the same internal fitting. Replaced it with the hose, reinstalled roll pin and fits like a glove. The only downside is that you don't have access to the hose unless you drop the tranny - but there isn't anything you can do about that if using the braided hose.
Also- the other option BCB sells is for an aftermarket master cylinder with AN fittings - not aftermarket slave assembly.
Mon Feb 15, 2016 2:53 pm
Great, glad you figured that out. Thanks.
I saw the other hose had a threaded end for an aftermarket M/C, I just thought the other end looked different too.
Mon Feb 15, 2016 6:07 pm
Progress was made today! Was able to get the ZF5 and Dana 20 installed. Had a few fitment issues with the JB Fab twin stick brackets. If I kept the D20 clocked in the stock position, it looks like it probably would have worked but I tucked it up a little bit and it changed the angles of the brackets. I had to do a little grinding and notching to get them to work. Big thanks to BroncoRaider for lending me some muscle-- I think I found a few chunks of headflesh on various underparts of my Bronco. Thanks for your help Tim!
A good look at my customer Harbor Freight crossmember! Design and fab of the cross member is next on my to do list.
The other thing with the twin stick shifters is that one sticks way into my gas pedal leg and the other gets caught on the tunnel cover. It appears that there will be some bending required. Anyone done this and have any tips/tricks/ or pictures?
Lastly-- might be a dumb question, but what is the other line on the slave assembly for? I can't seem to find that anywhere... (the top line in the picture that doesn't have the braided hose attached to it).
Tue Feb 16, 2016 6:11 pm
The top line is the bleeder to bleed the air out once it's all plumbed and installed. Just like replacing a brake caliper.
Tue Feb 16, 2016 6:54 pm
Tue Feb 16, 2016 6:57 pm
You can put a hose on the end to direct the fluid but it has a nipple on it just like a brake caliper. Usually I'll open that up and let the system gravity bleed for a while then I'll get help from someone by having them press the clutch pedal and hold it down while I open the bleeder. Literally just like replacing a brake caliper only with the clutch instead. Look up youtube videos if you want to make it easier than my explanation.
Tue Feb 16, 2016 7:24 pm
Tue Feb 16, 2016 9:05 pm
To bend the sticks you can use a propane torch to heat it up. When it starts to discolor/glow slowly bend it. I put it in a vice with some tags to keep it from getting chewed up. Go slow. And just enough heat to bed. There's some YouTube video out there about it.
Tue Feb 16, 2016 10:31 pm
Might also want to pick Zoso's brain to see how he bent his twin sticks?
Posted in his Page 2....ZOSO's toys...
Tue Feb 16, 2016 11:53 pm
I bent my twin sticks to clear my np435 shifter. Just heated till red with an oxy-acetylene torch, then bent to the desired angle. We can use mine if you want.
Wed Feb 17, 2016 12:46 am
Bleeding the ZF slave seems a bit harder than most others. I've had trouble as well as several others I have spoken to. I ended up having to bleed it manually with a crow-bar thru the access panel! This was after many attempts with someone depressing the clutch using the pedal. So put that in the back of your mind.
Before you pull your twin sticks, you might want to draw out some sort of pattern you think would work (cardboard or something). That will give you a template to follow.
Quench the rod with water after each bend as it stays hot a long time!
Wed Feb 17, 2016 4:39 am
Wed Feb 17, 2016 6:45 am
Twin sticks are bent and installed:
The ZF shifter in the picture is in neutral. The dash prevents it from going into 1,3,5th gear. Will need to fab a bracket to move it over and back a little.
Fri Feb 19, 2016 6:05 pm
Post #22 on this page has a pretty easy looking bracket. I'm hoping I can get away with something like it.
http://classicbroncos.com/forums/showth ... 977&page=2
Fri Feb 19, 2016 6:12 pm
Fri Feb 19, 2016 6:30 pm
Bends look good Eck!
Fri Feb 19, 2016 10:22 pm
You could always notch your dash
Fri Feb 19, 2016 11:57 pm
I think I'd like to try to straighten out my ZF shifter! Jealous of you guys with straight ones!! I like that idea of a small piece of plate! If you had to, you could even make the holes on a slight angle so lean the shifter out a little more.
Sat Feb 20, 2016 1:48 am
So I chose to ignore Chris's helpful suggestion of notching my dash. crazy
I did fab and install the bracket. I also shimmed the top bolt quite a bit to move the angle of the shifter out away from my leg. I think it is in a perfect spot now and clears both the dash as well as the twin sticks.
This is in 2nd gear:
This is in 1st gear:
The bracket:
Sun Feb 21, 2016 4:04 pm
The bracket with the many shims:
And the master cylinder installed with the braided line:
Sun Feb 21, 2016 4:05 pm
32,924,664 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
