www.ColoradoClassicBroncos.com - View topic - A bunch of Dana44 Axle Shafts - Various lengths
It is currently Thu Nov 21, 2024 5:00 pm
Reply to topic  [ 10 posts ]
Post A bunch of Dana44 Axle Shafts - Various lengths
I have a few different axle shafts from several different Dana 44 equipped trucks. I don't remember exactly where they are from but know one set is probably from full width F150 or F250, probably 74-77. I can take measurements if needed, tried to provide some in the pictures below. Willing to take what you think they are worth - let me know.
Sun Feb 14, 2016 9:59 pm
Post Re: A bunch of Dana44 Axle Shafts - Various lengths
Can you put together a bronco set from all your pieces? I don't have the measurement off the top of my head, but Zac needed a complete set.
Mon Feb 15, 2016 9:43 am
Mon Feb 15, 2016 10:43 am
I've got a trail spare set, I'll dig them out & measure as well.
Mon Feb 15, 2016 11:23 am
I do too. Just remembered. Will take measurements tonight and let you know.
Mon Feb 15, 2016 1:32 pm
Pulled out my backup front axle shafts and took some measurements.
Looks like these four outers are the same size
But the short side inners are not - one is 1/4" longer the other about 1" longer.
EB Inner length is 16.5"
One is 16.75"
two are 17"
The long side inner is way too long, not even close to a EB axle.
Don't know if that was helpful. one set of driver side might work. three of outers look to be a match.
let me know would love to get these out of my garage or i might turn them into art.
Mon Feb 15, 2016 10:56 pm
Outers should be the same between the EB and F150/Bronco axles (9 23/32" long as measured from the end of the axle to the center of the u-joint cap). Do you have any inners that are 18 29/32" and 33 29/32"? If so I'll take a full set. Otherwise I'll take one of the outers. I'm assuming the shiny aftermarket stuff in the pic is your spare?
Tue Feb 16, 2016 9:46 am
Set aside a couple of outers and the one inner that is close for Zac, I'll work on meeting up.
Tue Feb 16, 2016 1:07 pm
Tue Feb 16, 2016 4:44 pm
Tue Feb 16, 2016 4:52 pm
32,924,753 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
