It is currently Sat Nov 23, 2024 8:08 pm
[ 4 posts ] |
Need a 9" set up
Bought a 9". It's a 4.11 with Detroit. Needs to be set up again. Previous owner had it set up but backlash is pretty severe. Bottom line: I pull the third member, you set it up correctly, I reinstall.
Who is up for it? Let me know what it'll cost.
Thanks.
Fri Feb 19, 2016 11:23 pm |
Re: Need a 9" set up
How long was it run in current condition?
Sat Feb 20, 2016 9:53 am |
Unknown
Sat Feb 20, 2016 10:12 am |
Colorado75bronc
If it was run with a poor pattern for even a couple hundred miles or possibly less, and you change the pattern it will have gear whine.
Sent from my SAMSUNG-SM-G890A using Tapatalk
Sat Feb 20, 2016 1:45 pm |
[ 4 posts ] |
