It is currently Sat Nov 23, 2024 3:24 am
[ 11 posts ] |
Leaf spring damage
So I picked up a decent set of Tahoe springs yesterday. I picked them up east of Sagauche, about 1.5 hrs away (still closer than GJ or anyother salvage yards). They seem in good shape. But when I unloaded them into the garage today, I noticed one end had been cut with a grinding wheel. Its 1/16" deep at the worst, and about 3/8" long. I'm afraid its going to start cracking. Is it trash?
Sun Feb 21, 2016 3:03 pm |
Re: Leaf spring damage
Personally I wouldn't be worried about it. With the thickness of the metal there I would think you would be ok. Plus with the bushing/bolt in the stress will be spread out.
Sun Feb 21, 2016 3:09 pm |
X2. If you want peace of mind, just drop a bead in there with the welder.
Sun Feb 21, 2016 3:16 pm |
x2. I'd run it. There isn't much stress on that part on the spring.
Sun Feb 21, 2016 3:17 pm |
Sun Feb 21, 2016 3:20 pm |
I worked in a spring shop for several years and made custom leaf springs and leaf spring packs while there. The loads on that section of spring go opposite of the cut. Spring steel will snap with the right amount of load in the right direction. Your cut slightly weakens the spring across that section but is very unlikely enough to cause it to snap. Never weld spring steel. It crystallizes and becomes extremely brittle. I'd run that spring as is and never worry about it again.
Sun Feb 21, 2016 3:39 pm |
Great info. Thank you.
Sun Feb 21, 2016 7:33 pm |
Not a heavily loaded area. Just leave it as-is.
Sun Feb 21, 2016 10:35 pm |
Thank you. When I found the cut, I was pretty upset. I had convinced myself I needed to replace the damaged spring. I appreciate everyone's advice.
Mon Feb 22, 2016 8:24 am |
Gorilla Glue!
Mon Feb 22, 2016 10:50 am |
Moab Mike
Mon Feb 22, 2016 6:08 pm |
[ 11 posts ] |
Users browsing this forum: Google [Bot] and 4 guests |
