Project "X- Dezert Guy" '76 F150 prerunner
Postby Dirtheadz » Sat Mar 12, 2016 4:16 pm
Yes "Dezert" is intentionally spelled wrong... Lol. As many of you know: a) I'm a transplant from Las Vegas & b) yes... I used to race desert (4 stroke, open, 250 & 125 Nevada (AMA district 26) and Barstow (AMA district 37) area. Hanging out and countless races SNORE, SCORE, Best in the Desert, MRAN & MRANN, VORRA; pits and tech inspections, running from In & Out Burger & back with food. So desert (off-road racing) always remains in your blood. With that said & a recent acquisition from Pgilbeau, I'm starting my own tube chassis prerunner based off some of my favorite trucks (Steve Olliges class 8 amoung others). This is my first attempt at a complete tube chassis. I've back halved and tubed firewall to grill before, but this is my first 100%. The plan is to have this completed within 3 years, so this will be a slow build (more time then $$$$). Many of you (my friends) know, I'm cheap, and typically build as much as I can. Im actually on "Dezert Rangers" more than I'm on here at CCB, so you never what deals may pop up to expedite the build. Sorry for being so long winded.
The dream: I plan to run FOA's coilovers/ shocks & bumps (there cheap) 2.5's 16's front, 18's rear, 1-1/2 mounting width. 37's (wish 39 BFG Project TA's but gual durn). 9" rear, take TTB D44 outters and fab twin I beams with swing set steering. Fabbing my own 60" rear links (boats, canoe whatever the hip-sters are referring to them these days). 460/C6. 118" wheelbase (standard wheelbase) 84" track width (standard width).
Dirtheadz
Re: Project "X- Dezert Guy"
Postby Dirtheadz » Sat Mar 12, 2016 4:17 pm
The start
Dirtheadz
Postby Dirtheadz » Sat Mar 12, 2016 4:19 pm
Tear down
Dirtheadz
Postby Dirtheadz » Sat Mar 12, 2016 4:21 pm
Floors outta here... Laser level. Just a FYI... Will probably be cutting the firewall out as well
Dirtheadz
Postby Dirtheadz » Sat Mar 12, 2016 4:23 pm
Getting to the meat
Dirtheadz
Postby Dirtheadz » Sat Mar 12, 2016 4:24 pm
Front dress
Dirtheadz
Postby Dirtheadz » Sat Mar 12, 2016 4:27 pm
Do you even realize how hard it is to drill holes through double panels 6" apart & keep them straight and square????
Dirtheadz
Postby Dirtheadz » Sat Mar 12, 2016 4:29 pm
Found this while cutting the roof stiffener & part of the rear double panel. Yes I looked for the other 2/3's!!!!
Dirtheadz
Postby Colorado75bronc » Sat Mar 12, 2016 4:30 pm
Nice dude! Looking forward to seeing more!
Sent from my SAMSUNG-SM-G890A using Tapatalk
Colorado75bronc
Postby Dirtheadz » Sat Mar 12, 2016 4:31 pm
Rear cage hoop mock up
Dirtheadz
Postby Dirtheadz » Sat Mar 12, 2016 4:32 pm
Back half/ rail lay out.
Dirtheadz
Postby Dirtheadz » Sat Mar 12, 2016 4:36 pm
If this '79 doesn't give you wood, you may need Viagra!!!
Dirtheadz
Postby Dirtheadz » Sat Mar 12, 2016 4:38 pm
Sorry for the sideways pics guys
Dirtheadz
Postby Dirtheadz » Sat Mar 12, 2016 5:12 pm
Pics of the front down tubes through the firewall to dash bar (yes clearance the wipers is a b!tch)
Dirtheadz
Re: Project "X- Dezert Guy" '76 F150 prerunner
Postby pgilbeau » Sat Mar 12, 2016 9:06 pm
Looks good, your definitely moving faster than me. Looking forward to this build.
pgilbeau
Postby Digger » Sun Mar 13, 2016 12:08 am
You have my attention.
This was one of my favorites from SEMA last year
Postby Dirtheadz » Sun Mar 13, 2016 8:36 am
Ohhhhhh yeah, the F2000, twin turbo'd 460
Dirtheadz
Postby hockeydad4-22 » Sun Mar 13, 2016 8:43 am
Too friggin cool!
Postby Mr. Lav » Sun Mar 13, 2016 10:46 am
Awesome Ben.
Mr. Lav
Postby cravenbronco » Sun Mar 13, 2016 7:00 pm
I want one Ben :-)
cravenbronco
Postby Jesus_man » Mon Mar 14, 2016 2:17 am
And here it is!! Thanks for sharing the build!! I am loving it so far!!
Postby Dirtheadz » Mon Apr 25, 2016 4:04 pm
Slow go:
Dirtheadz
Postby Dirtheadz » Mon Apr 25, 2016 4:09 pm
Main cage bent & tacked. One of the tightest cages I've done.
Dirtheadz
Postby Dirtheadz » Mon Apr 25, 2016 4:11 pm
At least now I can start the main frame rails & cut the rest of the firewall out. Still need to tack in the roof bars.
Dirtheadz
Postby pgilbeau » Mon Apr 25, 2016 4:15 pm
Looking good!
pgilbeau
Postby Rox Crusher » Mon Apr 25, 2016 6:04 pm
Subscribing !
Please keep posting up the progress no matter how slow.
Postby Dirtheadz » Sun Jul 17, 2016 10:28 am
Been awhile so some pics. TTB D44 cutting the outters to make beams
Dirtheadz
Postby Dirtheadz » Sun Jul 17, 2016 10:31 am
Pics
Dirtheadz
Postby Dirtheadz » Sun Jul 17, 2016 10:36 am
Fabbing frame rails. The thought is full compression with 7in of ground clearance.
Dirtheadz
Postby Dirtheadz » Sun Jul 17, 2016 10:38 am
Pics
Dirtheadz
Next
