It is currently Sat Nov 23, 2024 5:28 am
[ 5 posts ] |
Reputable Colorado Springs Shop
Brent13
Joined: Tue Oct 06, 2015 9:19 am Posts: 48 Location: Colorado Springs
Hello All, Can any of you recommend a good shop in Colorado Springs that can dial in a carburetor? I put a brand new 600cfm Quick Fuel carb on in September. Had a a Motor-Head friend change the the jets for the altitude, ped it on the truck, and away I went. It runs pretty good, but I feel it could run a lot better. And it is certainly finicky when starting and when cold, certainly needs some choke work. Choke is electric. I just don't want to do this work as I am pretty clueless with carburetor work, and don't want to make it worse. I think it is close to running really well, just need that final tune. So what shop comes highly recommended? Thank you
_________________ 1974 Bronco, 302, C4
Sun Mar 13, 2016 10:10 pm |
RJLougee
Re: Reputable Colorado Springs Shop
The few times I've had anyone tune a carb, I took it to Don Allison off Hugo, on a Sat morning. I usually only drive a carb'd vehicle just long enough to collect the parts to convert everything to EFI.
Electrons I understand, that "Venturi Principle", magic..... Joe
Wed Mar 16, 2016 8:50 pm |
Thu Mar 17, 2016 6:26 am |
sykanr0ng
Years ago I was told that carburetor is a French word for "Don't f**k with it".
Thu Mar 17, 2016 10:37 pm |
Colorado75bronc
Greg Hutchinson is a good one too, Hutchinson Battery is the shop name 1 (719) 632-1326
Sent from my SAMSUNG-SM-G890A using Tapatalk
Sun Mar 20, 2016 9:25 am |
[ 5 posts ] |
