www.ColoradoClassicBroncos.com - View topic - TJ's 74 Bronco money pit
It is currently Thu Nov 21, 2024 10:44 am
Reply to topic  [ 259 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 9  Next
Post Re: TJ's 74 Bronco money pit
351, it's gonna be a copy of Phil's with aluminum heads.
TJ
F. Scott Fitzgerald
Wed Mar 30, 2016 7:45 am
I picked this up today in Milliken. The guy bought it 8 years ago but never mounted it he said it came from a guy who was down by Chatfield. Anyone recognize it?
TJ
F. Scott Fitzgerald
Wed Mar 30, 2016 6:42 pm
That's a cool looking hood, I've never seen one like that before. Nice score!
Wed Mar 30, 2016 10:36 pm
Never seen one like that either!
Thu Mar 31, 2016 1:02 am
Air craft stripper. 2 applications.
TJ
F. Scott Fitzgerald
Sat Apr 09, 2016 6:07 pm
You said stripper.....
Sat Apr 09, 2016 7:43 pm
Wow, that stuff is no joke, I bet the storm drain is running good.
Sat Apr 09, 2016 8:29 pm
Well I screwed up somewhere and had to strip it all over again. I don't think I let the primer dry for long enough.
TJ
F. Scott Fitzgerald
Fri Apr 15, 2016 5:11 am
I think that the original powder blue paint is the strongest substance known to man. That paint eats aircraft stripper and shits wire wheels.
TJ
F. Scott Fitzgerald
Fri Apr 15, 2016 5:17 am
Fri Apr 15, 2016 6:23 am
I thought about that, but I pressure washed it for 20 minutes. You could be right though so I'll use mineral spirits or something like that before painting.
TJ
F. Scott Fitzgerald
Fri Apr 15, 2016 7:03 am
Rinsing the stripper with water should have been ok. I would expect stripper to maybe hide in the nooks, crannies, and seams and maybe show up there, but not in the middle of a rinsed panel. What kind of primer? Rattle can or spray gun?
Fri Apr 15, 2016 7:28 am
Rattle can.
TJ
F. Scott Fitzgerald
Fri Apr 15, 2016 12:27 pm
I'd guess it wasn't cured. I'd strip it all again, unfortunately.
Mist some etch prime on the bare metal, & reprime. I wouldn't use a 'high build' or 'sandable' primer, just regular primer. One, maybe 2 coats. Then blast with color.
We have had bad luck with rattle can high build/sandable primers at the shop.
Fri Apr 15, 2016 12:36 pm
I will try it thanks.
TJ
F. Scott Fitzgerald
Fri Apr 15, 2016 1:53 pm
Welding is harder than it looks :Welding:
TJ
F. Scott Fitzgerald
Tue Apr 19, 2016 7:19 pm
Looks better in primer. I did a lot more prep this time around and it came out nice.
TJ
F. Scott Fitzgerald
Tue Apr 19, 2016 7:21 pm
Update.
TJ
F. Scott Fitzgerald
Wed Apr 20, 2016 5:28 pm
Looks great!
Thu Apr 21, 2016 1:32 am
Coming along! I'm about 50 lbs of wire into my welding career and have only been getting really nice welds in the past year or so. Making a strong weld isn't super hard, but making a pretty one can be.
Thu Apr 21, 2016 8:40 am
I decided to bed liner the Bronco. Here are some before and after pictures.
TJ
F. Scott Fitzgerald
Mon May 02, 2016 7:37 pm
Looks good! Which liner did you use?
Mon May 02, 2016 8:06 pm
That looks great! I'm looking forward to that myself.
Mon May 02, 2016 8:35 pm
I used duplicolor bed armor, but I sprayed it with a gun. I wire wheeled the whole thing first then washed with soap and water. It came out looking nice.
TJ
F. Scott Fitzgerald
Mon May 02, 2016 8:51 pm
Engine bay and Bed turned out really, Really nice!
Keep the pictures coming!
Good job man!
Mon May 02, 2016 9:51 pm
That looks great !
Tue May 03, 2016 2:25 am
What have I done to myself?
TJ
F. Scott Fitzgerald
Mon Aug 22, 2016 5:30 pm
Wiring is fun!
Mon Aug 22, 2016 6:15 pm
Mon Aug 22, 2016 7:05 pm
Mon Aug 22, 2016 7:09 pm
32,916,285 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
