It is currently Thu Nov 21, 2024 1:52 pm
Re: ZOSO's toys
Making some progress. Hoping to have it all together by tomorrow.
Sat Feb 27, 2016 8:45 am |
Re: ZOSO's toys
looking good....................don't forget to add a drain plug to the pan
Sat Feb 27, 2016 8:48 am |
Re: ZOSO's toys
Yikes! . . . . . . . . . . . . . Looks like you're making progress!
Sat Feb 27, 2016 3:49 pm |
Re: ZOSO's toys
Sat Feb 27, 2016 9:47 pm |
Re: ZOSO's toys
My progress was a little short today as I had some things to go do.
But I made good progress. I got all the sub assembly's built and ready to go. Tomorrow I will have it all back in the case and ready. Only thing im missing is the new shift rod but it's on its way.
Sat Feb 27, 2016 9:52 pm |
Re: ZOSO's toys
99% done. Need the shift rod and can button up the valve body the rest of the way.
decided to give the old valve a whack to see if I could get it out. it went flying across the garage. this is what it did to the valve.
Sun Feb 28, 2016 6:00 pm |
Re: ZOSO's toys
That'll buff out.
Sun Feb 28, 2016 6:52 pm |
Re: ZOSO's toys
Surprised that valve bent that far without breaking
Sun Feb 28, 2016 7:15 pm |
Re: ZOSO's toys
Sun Feb 28, 2016 8:15 pm |
Re: ZOSO's toys
Looks like a garage trophy to me!!
Mon Feb 29, 2016 4:52 am |
Re: ZOSO's toys
the man in brown has brought me some goodies. After going back and forth for what seems like a million times I just couldn't see spending $1700 on a pair of AFR heads. And with no reply for weeks from trickflow I pulled the trigger on the edelbrock e street. If in the future I need a bigger better flowing head i'll get these ported. The best part about the edelbrocks is no need for a spring change for a flat tappet cam. All other heads I would have had to change out the springs. Plus the $700 savings on these heads.
On another note. Went to finish the trans the other night. Trying to plug in the wiring board into all the solenoids and could not get the shift solenoid pack plugged in. Well come to find out instead of shipping me one for a 98 and later to match all the other electronics they send me a 97 and older. They don't mix. So now back to the waiting game for the correct one to get here.
Fri Mar 04, 2016 6:54 am |
Re: ZOSO's toys
Yup
Fri Mar 04, 2016 4:09 pm |
D&D72
Re: ZOSO's toys
Nice.... Real nice!
Sat Mar 05, 2016 8:11 am |
TOOLMAN
Re: ZOSO's toys
Mon Mar 07, 2016 8:24 am |
Re: ZOSO's toys
I screwed up and thought I had ordered the oil pump drive shaft but I guess I missed it. Once I get that I can get it mostly assembled and installed.
Mon Mar 07, 2016 9:40 am |
Re: ZOSO's toys
What's going on ?
Thu Mar 31, 2016 6:31 pm |
Re: ZOSO's toys
No progress. I have a pile of parts. Just lost motivation. hoping to take the heads to the shop to have em milled to my specs. Gotta order a few small parts to assemble the motor.
Thu Mar 31, 2016 7:07 pm |
Re: ZOSO's toys
USA performance is great. Dropped my heads off at noon to be milled .015" and they were done at 330. The heads are ready. Just need to place my summit order and I could have the engine back together and in.
Fri Apr 15, 2016 6:35 pm |
Re: ZOSO's toys
That's awesome ! Glad to see you back at it.
I think I'm nearing Bronco burnout, maybe I should take a break and regroup in a couple weeks........seems to have worked for you.
Fri Apr 15, 2016 6:46 pm |
Re: ZOSO's toys
Fri Apr 15, 2016 9:27 pm |
Re: ZOSO's toys
Got some goodies this week. All the parts to assemble the engine but harmonic balancer. Will get that set out to damper dudes this week.
Fri May 06, 2016 7:47 am |
Re: ZOSO's toys
Your oil pump drive shaft says 351C/400
Fri May 06, 2016 9:54 am |
Re: ZOSO's toys
Yes. Using the Explorer stuff requires a longer shafts. The 351c is 1/4" or so longer making a perfect fit.
Fri May 06, 2016 10:16 am |
Re: ZOSO's toys
Went with a 75mm throttle body.
Fri May 06, 2016 10:41 am |
Re: ZOSO's toys
Engine is assembled.
Fri May 06, 2016 3:46 pm |
Re: ZOSO's toys
Were you going for a rustic look on the block or do you still need to paint it?
Fri May 06, 2016 6:45 pm |
Re: ZOSO's toys
Was thinking of cleaning it and giving it a fresh coat. Just havent done it yet.
Fri May 06, 2016 9:20 pm |
Re: ZOSO's toys
I've been a little busy. Got the engine in last weekend. Trans went in today. Shooting for tcase and such tomorrow. Getting closer yet. Still need to order my -6 hose and fittings for everything.
Fri May 13, 2016 6:30 pm |
Re: ZOSO's toys
Down to the little things. Gotta figure out a lower radiator hose. Need to plumb the trans lines and finish the wiring. Then figure out an intake tube that'll fit this 4in maf. Hoping to have it close to fire this weekend. May require some long nights but Im trying.
Mon Aug 08, 2016 11:13 am |
Re: ZOSO's toys
Might try this place.. they are in the springs but ship. Was happy with my stuff from them http://www.siliconeintakes.com/
Mon Aug 08, 2016 12:28 pm |
