www.ColoradoClassicBroncos.com - View topic - Rox Crusher's 77 sport
It is currently Thu Nov 21, 2024 8:11 am
Reply to topic  [ 307 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9, 10, 11  Next
Post Re: Rox Crusher's 77 sport
I bought all new lifters for my build. You probably know how to do it but here is a link I found useful. It's how to check pushrod length.
https://m.youtube.com/watch?v=5MjAxnGeGKw
TJ
F. Scott Fitzgerald
Fri Apr 15, 2016 2:03 pm
everything but the pushrods are new...........
thank you for that link, it was helpful
Fri Apr 15, 2016 5:31 pm
Pull one that's the correct length and one that's loose. Measure them. If the same I'd say you have some lifters that are collapsed. Did you soak the new lifters in a bucket of oil? Pump them up? Prime the oil system before starting?
Fri Apr 15, 2016 6:46 pm
Fri Apr 15, 2016 6:48 pm
Just retorque them. They should be bled by now.
Fri Apr 15, 2016 6:59 pm
If you didn't prime the engine before starting it the lifters will scream for a bit. That hour soak won't do much. It'll take a little while before they get pumped up enough to not clatter. Fire it up and let run for a bit, they'll quiet down.
Sat Apr 16, 2016 8:47 am
Its on a harley but works for all hydraulic lifters. https://www.youtube.com/watch?v=g84UKZg8zZk
If these are pedistal rockers they are not adjustable. if they are stud mounted then the loose pushrods should have the lash adjusted.
Sat Apr 16, 2016 9:23 am
they are pedestal rockers.
So how long should I expect to run the motor to get the lifters to prime themselves ?
Sat Apr 16, 2016 11:47 am
Could be less than a minute or it could be 10. Or, to be safe, you could pop the distributer out(cam sensor if distributerless) and prime the system well before another start up!
Sat Apr 16, 2016 3:45 pm
get a primer and pop the cps out. hook it to a good drill. Run it for a while to pump it up. leave the valve cover off and keep checking the "loose" pushrod to see if it tightens up.
Sat Apr 16, 2016 4:08 pm
I checked the torque on the rockers and they were all good.
I let it idle for almost 20 minutes. It seemed to quiet down some, and while it is still pretty noisy, but it no longer has an erratic sound to it.
I'm guessing the lifters are now primed and that the pushrods are now tight.
Still noisier than I think they should be so I will probably remove the valve cover again and check for lose ones.
Sat Apr 16, 2016 5:02 pm
well did it get any better?
Fri Apr 22, 2016 7:27 am
Fri Apr 22, 2016 8:07 am
Fri Apr 22, 2016 6:20 pm
So, The Bronco Master (not you Shawn) figured out precisely what was needed.........which meant we had to go with push rods that were 60 thoughsanths longer and use a 30 thousandths shim to get the effective length we needed.
It now purrs like a roller rocker kitten.
Just gotta get the exhaust leak at the passenger side collector sealed up. This is the same place we had trouble on Phil's.
Thank you Phil !
Mon Apr 25, 2016 7:14 pm
Mon Apr 25, 2016 8:00 pm
Tue Apr 26, 2016 11:09 am
Tue Apr 26, 2016 1:43 pm
Tue Apr 26, 2016 2:13 pm
351w test drive. https://youtu.be/XgPHrVymUbM
Thu Apr 28, 2016 4:54 pm
Like!
Thu Apr 28, 2016 5:33 pm
Dude, your hood is missing...
So you going to Moab?!
Thu Apr 28, 2016 5:41 pm
Sweet!
Thu Apr 28, 2016 8:13 pm
Very nice but I was expecting a 100' burnout!
Thu Apr 28, 2016 9:15 pm
foshizzle
Fri Apr 29, 2016 7:37 am
Which exhaust is that?
Fri Apr 29, 2016 8:23 am
Dat sumanabastich sounds fargin sweet!
Fri Apr 29, 2016 10:07 am
Fri Apr 29, 2016 11:08 am
Fri Apr 29, 2016 11:09 am
Fri Apr 29, 2016 11:10 am
32,911,619 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
