It is currently Sat Nov 23, 2024 6:11 pm
cpldavis37
Re: TJ's 74 Bronco money pit
351, it's gonna be a copy of Phil's with aluminum heads.
Wed Mar 30, 2016 7:45 am |
cpldavis37
I picked this up today in Milliken. The guy bought it 8 years ago but never mounted it he said it came from a guy who was down by Chatfield. Anyone recognize it?
Wed Mar 30, 2016 6:42 pm |
That's a cool looking hood, I've never seen one like that before. Nice score!
Wed Mar 30, 2016 10:36 pm |
Never seen one like that either!
Thu Mar 31, 2016 1:02 am |
cpldavis37
Air craft stripper. 2 applications.
Sat Apr 09, 2016 6:07 pm |
You said stripper.....
Sat Apr 09, 2016 7:43 pm |
Wow, that stuff is no joke, I bet the storm drain is running good.
Sat Apr 09, 2016 8:29 pm |
cpldavis37
Well I screwed up somewhere and had to strip it all over again. I don't think I let the primer dry for long enough.
Fri Apr 15, 2016 5:11 am |
cpldavis37
I think that the original powder blue paint is the strongest substance known to man. That paint eats aircraft stripper and shits wire wheels.
Fri Apr 15, 2016 5:17 am |
Fri Apr 15, 2016 6:23 am |
cpldavis37
I thought about that, but I pressure washed it for 20 minutes. You could be right though so I'll use mineral spirits or something like that before painting.
Fri Apr 15, 2016 7:03 am |
Rinsing the stripper with water should have been ok. I would expect stripper to maybe hide in the nooks, crannies, and seams and maybe show up there, but not in the middle of a rinsed panel. What kind of primer? Rattle can or spray gun?
Fri Apr 15, 2016 7:28 am |
cpldavis37
Rattle can.
Fri Apr 15, 2016 12:27 pm |
I'd guess it wasn't cured. I'd strip it all again, unfortunately.
Mist some etch prime on the bare metal, & reprime. I wouldn't use a 'high build' or 'sandable' primer, just regular primer. One, maybe 2 coats. Then blast with color.
We have had bad luck with rattle can high build/sandable primers at the shop.
Fri Apr 15, 2016 12:36 pm |
cpldavis37
I will try it thanks.
Fri Apr 15, 2016 1:53 pm |
cpldavis37
Welding is harder than it looks
Tue Apr 19, 2016 7:19 pm |
cpldavis37
Looks better in primer. I did a lot more prep this time around and it came out nice.
Tue Apr 19, 2016 7:21 pm |
cpldavis37
Update.
Wed Apr 20, 2016 5:28 pm |
Looks great!
Thu Apr 21, 2016 1:32 am |
Coming along! I'm about 50 lbs of wire into my welding career and have only been getting really nice welds in the past year or so. Making a strong weld isn't super hard, but making a pretty one can be.
Thu Apr 21, 2016 8:40 am |
cpldavis37
I decided to bed liner the Bronco. Here are some before and after pictures.
Mon May 02, 2016 7:37 pm |
Looks good! Which liner did you use?
Mon May 02, 2016 8:06 pm |
BroncoRaider
That looks great! I'm looking forward to that myself.
Mon May 02, 2016 8:35 pm |
cpldavis37
I used duplicolor bed armor, but I sprayed it with a gun. I wire wheeled the whole thing first then washed with soap and water. It came out looking nice.
Mon May 02, 2016 8:51 pm |
Engine bay and Bed turned out really, Really nice! Keep the pictures coming! Good job man!
Mon May 02, 2016 9:51 pm |
That looks great !
Tue May 03, 2016 2:25 am |
cpldavis37
What have I done to myself?
Mon Aug 22, 2016 5:30 pm |
Wiring is fun!
Mon Aug 22, 2016 6:15 pm |
Mon Aug 22, 2016 7:05 pm |
Mon Aug 22, 2016 7:09 pm |
