It is currently Sat Nov 23, 2024 1:11 am
[ 28 posts ] |
tailgate repair advice
Tue Apr 19, 2016 9:39 pm |
Re: tailgate repair advice
If you are worried the whole width is thin, then replace it with a flat patch. Cutting it out and patching it will give you better metal & a flange to weld or glue to.
Tue Apr 19, 2016 10:27 pm |
I've seen a guy use freeze plugs that he welded into the ends.
Tue Apr 19, 2016 11:01 pm |
You could weld in a flat piece there but just have to note that's where the seal touches the tailgate. You may then have to adjust the seal when you get to that point.
Wed Apr 20, 2016 5:42 am |
That's what I figured. I will evaluate the rot I think it would be best to remove that whole section the metal is thin in places.
Wed Apr 20, 2016 7:52 am |
plumbdoctor
the panel I have has that raised portion included....might get one with the same style?
Wed Apr 20, 2016 9:24 pm |
Wed Apr 20, 2016 10:14 pm |
casadejohnson
yea, where? I'm in the same boat
Wed Apr 20, 2016 10:28 pm |
Thu Apr 21, 2016 6:11 am |
What keith has looks like the top of the tail gate.
Thu Apr 21, 2016 6:13 am |
That's what I was wondering. I might be able to cut the embossing out of that and graft it in. But not sure it's even worth it.
Thu Apr 21, 2016 7:24 am |
Dirtheadz
ive got a bead roller and could probably duplicate a similar embossing if interested
Thu Apr 21, 2016 8:24 am |
Iam but your so far away let me see what I can do locally. I need to pick up a sheet of 16/18 gauge
Thu Apr 21, 2016 9:21 pm |
plumbdoctor
Its the lower, picked it up from Duff's, the only issue with it is that the raised portion goes end to end. Gonna need some hammer and dolly work to get it to look like the stock raised portion. Over all a pretty decent piece.
Fri Apr 22, 2016 4:11 pm |
plumbdoctor
I will take a better pic tonight to show the whole thing...the pic I posted does make it look like the top piece though..
Fri Apr 22, 2016 4:14 pm |
plumbdoctor
As you can see, they rolled it all the way out to the ends, take a little work to flatten off the ends for the stock look,
Fri Apr 22, 2016 9:47 pm |
I went and bought some 17 gauge and found a shop to roll a bead on one side and bend up an approximation of the emboss. I think the thick one should work fine, I will just flatten off the ends and be done with it.
Sat Apr 23, 2016 1:36 pm |
I'm glad you are doing something to replicate it. Only because its an eyebrow tailgate. You could sell/trade up if yours comes out nice enough.
Sat Apr 23, 2016 1:39 pm |
Sun Apr 24, 2016 7:45 pm |
Looks great!
Sun Apr 24, 2016 8:01 pm |
Nice. Like the extra profile you added.
Sun Apr 24, 2016 9:08 pm |
Starting to grind things down. Will sand and do more later this week. Rain put a damper on my workshop time.
Mon Apr 25, 2016 7:30 pm |
Got most of the grinding done. Started working on flattening the ends of the embossing. Should have done this before i welded it in but I will make it work.
Wed Apr 27, 2016 10:59 pm |
a little bit of seam sealer here and there and i think its good enough for now.
Sun May 01, 2016 1:24 pm |
Looks awesome. Good work.
Sun May 01, 2016 1:53 pm |
Installed! Ruff!
Wed May 04, 2016 8:24 pm |
Wed May 04, 2016 9:34 pm |
Otis is ready for a ride to the lake
Fri May 06, 2016 2:50 pm |
[ 28 posts ] |
Users browsing this forum: No registered users and 47 guests |
