It is currently Thu Nov 21, 2024 8:52 am
Re: Rox Crusher's 77 sport
Fri Apr 29, 2016 11:11 am |
Fri Apr 29, 2016 11:39 am |
lol, nice.
Fri Apr 29, 2016 2:01 pm |
That very evil thing happened today
Tue May 03, 2016 9:07 pm |
BroncoRaider
Does evil = body lift?
Tue May 03, 2016 9:54 pm |
Wed May 04, 2016 4:15 am |
THIS JUST IN
Turns out that a 1" body lift, combined with a heavy duty fender washer, allows me to use the stock hood after all.
I need to tweak a few little things under the hood to help the throttle position sensor clear but that ain't nuttin budda thang at this point.
Thank you evil body lift !
Wed May 04, 2016 12:49 pm |
Wed May 04, 2016 2:11 pm |
BroncoRaider
Like. The next question is when are we putting that cage in?
Wed May 04, 2016 3:22 pm |
Wed May 04, 2016 4:05 pm |
Looks good!
It wouldn't be hard to do. I'll look at my grill tonight and try to figure something out. I only have 16g metal right now, sort of tough to work with. I need to get my hands on some 18g, just hate to pay Gunnison prices.
Wed May 04, 2016 5:00 pm |
Wed May 04, 2016 8:04 pm |
D&D72
Bitchin......
Wed May 04, 2016 8:36 pm |
[quote="mickphatmac"] You might just have to run the plow year round and then you'll never see it! [\quote]
That plow now belongs to the F1 Fiddy
Wed May 04, 2016 8:45 pm |
Wed May 04, 2016 9:10 pm |
Moab Mike
Nice work Jeff!
Thu May 05, 2016 5:47 am |
Thu May 05, 2016 6:09 am |
what's your clearance Clarence
A wise man told me I should go ahead and pre-clearance my oil pan
Thu May 12, 2016 8:17 pm |
So the body lift is on, the shifter linkage has been extended, the fan shroud has been removed for a little bit of re-work, and the floor has been trimmed to allow the twin sticks to function.
Started it up and it was making a helluva racket. Sounded like it was coming from bell housing area so quickly shut it down. Sounded like the flex plate or torque converter nuts were hitting the block plate.
Thought I might have messed something up with the shifter linkage or transfer case which I forgot to double check before starting it.
On top of this, it has been leaking oil pretty good at the pan - front and rear. We thought it was leaking up front and running along the flange of the pan and then down the back of the pan and block plate.
Thought it might be a bad stroke of luck and maybe the rear main seal had popped out somehow and was getting chewed up and making that awful noise.
I tried starting it several times in gear, neutral, transfer case in neutral and the noise remained. Took the trans inspection plate off and everything up there looked awesome. The noise was rotational but the crossover tube had been touching the inspection cover so I took it off. Still the noise remained. Really loud and perplexing. Was starting to think something had gone "Eck-ish" in the motor.
I stood at the front of the Bronco, placed my head on the radiator, arms draped into engine bay grasping at straws / ideas. My hands fell on the fan and I gave it a spin and it was hitting / hanging up on the lower radiator hose as the shroud was no longer there to keep it away.
Zip tied the hose and started it up and noise was no longer there.
They say it can be better to be lucky, than good.
I'm a believer !
Thu May 12, 2016 8:42 pm |
Glad it turned out to be non "Eck-ish". Noises make people !! https://static-secure.guim.co.uk/sys-im ... ng-008.jpg
Thu May 12, 2016 9:18 pm |
BroncoRaider
Is the '77 going to make an appearance in Aurora on Saturday?
Thu May 12, 2016 9:44 pm |
Fri May 13, 2016 5:11 am |
whats going on in Aurora?
Fri May 13, 2016 5:18 pm |
Fri May 13, 2016 5:26 pm |
What time need address
Fri May 13, 2016 5:55 pm |
Well, I put a good 50 miles on it this evening.
Love the motor !
Never got over 193. Oil pressure of 47 while running, 19 at idle.
Fuel pressure 62 PSI while riding, drops to 55 at WOT.
Got a check engine light when I fired it back up after checking oil level and it is still leaking at rear of pan.
More opportunities to tinker I guess.
Sun May 15, 2016 6:18 pm |
Awesome, can't wait to see it.
Sun May 15, 2016 6:56 pm |
Drove it up 470 in the afternoon heat yesterday (85) and it got as hot as 221.
I guess I better get my fan shroud figured out soon.
Sun May 22, 2016 10:24 am |
Ordered the Vintage Air Gen IV today !
Figured I might as well put it in before installing roll cage and carpet.
Fri May 27, 2016 3:48 pm |
Sweet! That'll be a nice addition!
Fri May 27, 2016 3:56 pm |
