Rox Crusher's 77 sport
Re: Rox Crusher's 77 sport
Postby Rox Crusher » Fri Apr 29, 2016 10:11 am
D&D72 wrote:Dat sumanabastich sounds fargin sweet!
thanks
still need to fix a leak at the collector on the passenger side and add a CAT so it will probably change a bit
Postby landshark » Fri Apr 29, 2016 10:39 am
Postby Digger » Fri Apr 29, 2016 1:01 pm
lol, nice.
Postby Rox Crusher » Tue May 03, 2016 8:07 pm
That very evil thing happened today
Postby BroncoRaider » Tue May 03, 2016 8:54 pm
Does evil = body lift?
BroncoRaider
Postby Rox Crusher » Wed May 04, 2016 3:15 am
BroncoRaider wrote:Does evil = body lift?
You guessed er', Chester
But it appears the new hood now fits
Gonna try the stock hood today just for giggles
How's your engine coming together ?
Postby Rox Crusher » Wed May 04, 2016 11:49 am
THIS JUST IN
Turns out that a 1" body lift, combined with a heavy duty fender washer, allows me to use the stock hood after all.
I need to tweak a few little things under the hood to help the throttle position sensor clear but that ain't nuttin budda thang at this point.
Thank you evil body lift !
Postby landshark » Wed May 04, 2016 1:11 pm
Rox Crusher wrote:THIS JUST IN
that body gap near the bumper looks awful! :)
Congrats! looking good
Postby BroncoRaider » Wed May 04, 2016 2:22 pm
Like. The next question is when are we putting that cage in?
BroncoRaider
Postby Rox Crusher » Wed May 04, 2016 3:05 pm
Thank you, I am excited about being able to keep the stock hood.
so, wrt that gap..........................do you know any good auto body guys that could make a piece that fills that gap in ?
calling Gunnibronco and / or JGZ !
Postby Gunnibronco » Wed May 04, 2016 4:00 pm
Looks good!
It wouldn't be hard to do. I'll look at my grill tonight and try to figure something out. I only have 16g metal right now, sort of tough to work with. I need to get my hands on some 18g, just hate to pay Gunnison prices.
Postby mickphatmac » Wed May 04, 2016 7:04 pm
LOL!!!
That's exactly why I don't want a Body Lift!!!
I do like the idea of a lower front grill roll pan.
You might just have to run the plow year round and then you'll never see it!
The stock hood is definitely where it's at thumbs up thumbs up thumbs up
Postby D&D72 » Wed May 04, 2016 7:36 pm
Bitchin......
D&D72
Postby Rox Crusher » Wed May 04, 2016 7:45 pm
[quote="mickphatmac"] You might just have to run the plow year round and then you'll never see it!
[\quote]
That plow now belongs to the F1 Fiddy
Postby mickphatmac » Wed May 04, 2016 8:10 pm
Rox Crusher wrote:That plow now belongs to the F1 Fiddy
Well we might have to think of new names like "Gappy", "Win one for the Gapper"...or maybe just.... "Michael Strayhan" :laughing2:
Postby Moab Mike » Thu May 05, 2016 4:47 am
Nice work Jeff! thumbs up
Moab Mike
Postby ZOSO » Thu May 05, 2016 5:09 am
How about a winch bumper and winch. That'll fix it up just right.
what's your clearance Clarence
Postby Rox Crusher » Thu May 12, 2016 7:17 pm
A wise man told me I should go ahead and pre-clearance my oil pan
Postby Rox Crusher » Thu May 12, 2016 7:42 pm
So the body lift is on, the shifter linkage has been extended, the fan shroud has been removed for a little bit of re-work, and the floor has been trimmed to allow the twin sticks to function.
Started it up and it was making a helluva racket. Sounded like it was coming from bell housing area so quickly shut it down. Sounded like the flex plate or torque converter nuts were hitting the block plate.
Thought I might have messed something up with the shifter linkage or transfer case which I forgot to double check before starting it.
On top of this, it has been leaking oil pretty good at the pan - front and rear. We thought it was leaking up front and running along the flange of the pan and then down the back of the pan and block plate.
Thought it might be a bad stroke of luck and maybe the rear main seal had popped out somehow and was getting chewed up and making that awful noise.
I tried starting it several times in gear, neutral, transfer case in neutral and the noise remained. Took the trans inspection plate off and everything up there looked awesome. The noise was rotational but the crossover tube had been touching the inspection cover so I took it off. Still the noise remained. Really loud and perplexing. Was starting to think something had gone "Eck-ish" in the motor.
I stood at the front of the Bronco, placed my head on the radiator, arms draped into engine bay grasping at straws / ideas. My hands fell on the fan and I gave it a spin and it was hitting / hanging up on the lower radiator hose as the shroud was no longer there to keep it away.
Zip tied the hose and started it up and noise was no longer there.
They say it can be better to be lucky, than good.
I'm a believer !
Postby Eck » Thu May 12, 2016 8:18 pm
Glad it turned out to be non "Eck-ish". Noises make people crazy!! https://static-secure.guim.co.uk/sys-im ... ng-008.jpg
Postby BroncoRaider » Thu May 12, 2016 8:44 pm
Is the '77 going to make an appearance in Aurora on Saturday?
BroncoRaider
Postby Rox Crusher » Fri May 13, 2016 4:11 am
BroncoRaider wrote:Is the '77 going to make an appearance in Aurora on Saturday?
Yes, the 77 F150 will be there
Postby landshark » Fri May 13, 2016 4:18 pm
whats going on in Aurora?
Postby Rox Crusher » Fri May 13, 2016 4:26 pm
landshark wrote:whats going on in Aurora?
we are going to install motor and tranny in buddy tomorrow
bring it !
Postby landshark » Fri May 13, 2016 4:55 pm
What time need address
Postby Rox Crusher » Sun May 15, 2016 5:18 pm
Well, I put a good 50 miles on it this evening.
Love the motor !
Never got over 193. Oil pressure of 47 while running, 19 at idle.
Fuel pressure 62 PSI while riding, drops to 55 at WOT.
Got a check engine light when I fired it back up after checking oil level and it is still leaking at rear of pan.
More opportunities to tinker I guess.
Postby Digger » Sun May 15, 2016 5:56 pm
Awesome, can't wait to see it.
Postby Rox Crusher » Sun May 22, 2016 9:24 am
Drove it up 470 in the afternoon heat yesterday (85) and it got as hot as 221.
I guess I better get my fan shroud figured out soon.
Postby Rox Crusher » Fri May 27, 2016 2:48 pm
Ordered the Vintage Air Gen IV today !
Figured I might as well put it in before installing roll cage and carpet.
Postby Justin » Fri May 27, 2016 2:56 pm
Sweet! That'll be a nice addition!
