It is currently Sat Nov 23, 2024 1:05 am
[ 6 posts ] |
rlm18
Joined: Thu Apr 03, 2014 11:23 am Posts: 58 Location: Colorado and Arkansas
Engine Identification
I am trying to figure out exactly what engine I have to make parts buying easier. I am going to be replacing some seals sometime in the future. I always feel like an idiot at the parts store. "Car make and model? Well....." Looking at old paperwork it could be an 80 - 85 model 302. Supposed to be an 80's model mustang 302 as per the p.o. It has an oil pan with two drain plugs, one front and one rear. Mustang? I pulled the starter to look at the numbers on the engine. E0AE D3C 8 3B2? I have been trying googling decoding. I have not been able to figure out what it all means. A model 80 car 302? Appreciate the help!
_________________ 74. A few different shades of yellow, black, and rust. 80's 302 w/ edelbrock carb. 80's 4spd on the floor w/ dana 20 twin stick. dana 44 in front and full floating 31 spline ford 9" rear with a detroit locker. 4.56 gearing. 5 1/2" of lift w/ 35" general grabbers.
Thu May 19, 2016 10:12 pm |
Re: Engine Identification
Appears to be a 1983 casting. 3B2: 3=1983 B=February (B is the second letter in the alphabet, Feb is the second month) 2=day of the month it was cast.
Should still be a 28oz balance motor. Actual vehicle application isn't too important until you get to a water pump or oil pump, in which case you can just ask for something from a Bronco.
Thu May 19, 2016 10:28 pm |
Thu May 19, 2016 11:07 pm |
Thu May 19, 2016 11:44 pm |
sykanr0ng
Fri May 20, 2016 3:23 am |
rlm18
Ahhh that's what the 3B2 means. Appreciate it! I'll have to study up on the balance. Thank you again!
Fri May 20, 2016 7:35 pm |
[ 6 posts ] |
Users browsing this forum: No registered users and 59 guests |
