[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 379: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
It is currently Thu Nov 21, 2024 7:56 pm
Reply to topic  [ 477 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10, 11, 12 ... 16  Next
Post Re: New Member 69
Wiper upgrade was straight forward, but it sucks trying to find small pin style 14" blades.
by , on Flickr
by , on Flickr
I had to straighten out one of the bends to make it match the other arm and fit the windshield
by , on Flickr
by , on Flickr
And 4 quick and dirty spring retainers.
by , on Flickr
Sat Apr 09, 2016 11:37 pm
That tire carrier is awesome. Again, you do some sick work.
Sun Apr 10, 2016 7:26 am
You have all the cool toys!
Mon Apr 11, 2016 7:54 am
Nice! I have tool envy. Wait, that sounds bad...
Mon Apr 11, 2016 8:56 pm
Getting back at it after Super Celebration. During the road trip to TN and back, I really learned how much I disliked the original cam that came with the engine. It was just too hot for a street-driven truck. After some research and discussion with Viperwolf, I ordered this:
by , on Flickr
Saying Good-bye to a few components under the hood.
by , on Flickr
I tore the engine down and replace valve stem seals while it was apart.
by , on Flickr
by , on Flickr
by , on Flickr
by , on Flickr
New Cam:
by , on Flickr
by , on Flickr
Going back together
by , on Flickr
by , on Flickr
She's alive!
Fri Jun 10, 2016 11:23 pm
While everything was apart, it was time to a brake upgrade:
by , on Flickr
Wish me luck. This is going to be a tight fit and I'm trying not to permanently modify the hydroboost unit.
by , on Flickr
Fri Jun 10, 2016 11:24 pm
Good luck!
Sat Jun 11, 2016 4:17 am
Got to work making brackets for the hydroboost
by , on Flickr
by , on Flickr
by , on Flickr
by , on Flickr
by , on Flickr
Made a new master cylinder pushrod since the hydroboost doesn't include one.
by , on Flickr
Fittings and hose showed up from Speedway.
by , on Flickr
All assembled
by , on Flickr
Installation
by , on Flickr
by , on Flickr
Breather / Fill vent was going to be in the way and was redundant anyhow, so I turned out a quick fill plug.
by , on Flickr
by , on Flickr
by , on Flickr
Thu Jun 16, 2016 11:52 pm
Looks great, how thick is the sheet steel used in the firewall bracket?
Fri Jun 17, 2016 5:37 am
Amazing work.
Fri Jun 17, 2016 8:34 am
Fri Jun 17, 2016 9:38 am
Very nice and clean looking
Fri Jun 17, 2016 1:03 pm
Yee Haw! We have brakes!! And whoa buddy, hydroboost is AWESOME! Nothing like being able to lockup 37s on command.
The last bit of work was plumbing the power steering lines and brake lines, then bleeding out both systems.
GM power steering O-ring to -6AN adapters. Both the hydroboost unit and Saginaw steering gear use a M18x1.5 on the input and M16x1.5 output. The Saginaw pump uses a M16x1.5 on the output.
by , on Flickr
by , on Flickr
by , on Flickr
by , on Flickr
Pedal feel is very good. Not too heavy, not too light.
Mon Jun 20, 2016 10:39 pm
You are just a computer, a high pressure fuel pump, and some injectors away from having modern performance in a classic body!
Mon Jun 20, 2016 11:10 pm
T h a t ' s Awesome!!!
"Breather / Fill vent was going to be in the way and was redundant anyhow, so I turned out a quick fill plug."
SHOW-OFF!!!!!
BTW, That Hydroboost looks Soooo much better than that Big, Fat, Ugly Brake Booster! :laughing2:
Tue Jun 21, 2016 8:14 am
Looks great! I may need to "borrow" your idea for the mounting bracket to get mine to clear the intake when I go EFI.
Tue Jun 21, 2016 6:24 pm
So, whats the status on your TBI? Been quite a while since we have seen an update on that. Everything else is amazing!
Tue Jun 21, 2016 8:22 pm
Wed Jun 22, 2016 8:31 am
Wed Jun 22, 2016 8:35 am
Cool. looking forward to it almost as much as you!
Thu Jun 23, 2016 2:13 am
Goodbye carburetor.
by , on Flickr
TBI unit vs Holley
by , on Flickr
Pulled out the fittings for the carb install
by , on Flickr
Dropped on TBI unit and plumbed fuel lines to the regulator block
by , on Flickr
Punching holes for the computer
by , on Flickr
by , on Flickr
The computer needed to be mounted to its front face with the AMP connector sticking through the firewall. This required some spacers be made.
by , on Flickr
by , on Flickr
Installed
by , on Flickr
by , on Flickr
Not fancy, but this was my quick and dirty way of routing the large wideband O2 connectors through the body and mounting the wideband controller. I'll go back and make a proper mount later, but this works for now.
by , on Flickr
Pulled the exhaust and welded in the O2 bung
by , on Flickr
Wed Jun 29, 2016 10:34 pm
A whole lot of wiring.
by , on Flickr
I got some cage-mounted mirrors for my birthday. If I get this thing running, I'll be running doorless this summer.
by , on Flickr
I pulled the MSD distributor out and locked out the mechanical advance
by , on Flickr
Uploading the latest firmware to the Microsquirt
by , on Flickr
After verifying all the sensors worked, I test fired the engine. It's wasn't smooth, but everything was working, so I loom-tube'd the wiring and locked everything down
by , on Flickr
Now I'm in the tuning phase, but I appear to be fighting a bad idle air valve. Even with power removed, it still won't suck the valve shut and the engine is idling at 1100 rpm. I messed around with an adjuster screw on the IAC, but is doesn't help much. The engine at least is running smooth at one point on the map, but until I get this idle valve resolved, I'm stuck.
Wed Jun 29, 2016 10:39 pm
Damn you do good work!
So seriously, is there anything you can't weld, engineer, make, fabricate, wire, etc!!!???
So jealous!
Wed Jun 29, 2016 11:11 pm
More info on the mirrors please!!
the TBI set up looks good so far. Some tuning to smooth it out or??
Thu Jun 30, 2016 1:23 am
Thu Jun 30, 2016 10:02 am
Ugh, bumpers. I'm low on ideas
I'm trying to make something cool, something different, something functional. There is not a lot of innovation with bumpers, plus there are too many directions to go.
Here is where it sits tonight. It's rough, but hopefully getting somewhere.
by , on Flickr
Wed Nov 16, 2016 11:35 pm
What is your main structure going to be? Are you breaking plate or welding pieces together? Your design looks great, but I'm worried about strength between the frame rails.
Thu Nov 17, 2016 4:03 pm
I'm happy to see a 8274 rendered! I've always wanted to see a modern design incorporating it, the '70s stuff is ugly.
Thu Nov 17, 2016 4:17 pm
Thu Nov 17, 2016 10:12 pm
I like the looks of it so far
I was thinking those front corner pieces were going to be made out of machined aluminum, like a fairlead kind of look
Fri Nov 18, 2016 8:04 am
32,929,159 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
