Register •
FAQ
• Login
It is currently Sun Nov 24, 2024 11:10 pm
project viperwolfe is starting
Re: project viperwolfe is starting
The shroud did help at low speed and idle in the triple digits. I did get some temp creep at high speed in those temps though. At cooler temps the engine runs within a couple degrees of the thermostat temp (193-195). Over 95 degrees would make creep to 203 after 10 miles on the highway at 70 mph. I know it doesn't sound terrible but this is on flat ground. So I did some research and found a replacement explorer radiator that had a 1/2" thicker core. Still 2 rows of tubes but each 1/4" wider. Total cost $118 at Summit. Now I have to wait for it to get hot again so I can put it to the test.20160607_175543.jpg
Tue Jun 07, 2016 9:54 pm |
If it makes a difference I'll need a part # please.
Wed Jun 08, 2016 4:55 am |
Wed Jun 08, 2016 11:34 am |
Watching with much interest.
I'm going to put the shroud on mine and see how it does with the summer temps arriving in CO.
I'm thinking I may have to change out my Bronco radiator for your set up, especially if I now have to install air conditioner condenser in front of radiator.
Will be curious about trans temps too as I currently run mine through an auxiliary cooler. Ousted in front of radiator.
Fri Jun 10, 2016 6:14 pm |
I decided to plug some holes around the radiator while I was at it. 20160609_182644.jpg 20160609_182702.jpg 20160609_182712.jpg
Fri Jun 10, 2016 8:36 pm |
Sun Jun 19, 2016 4:13 pm |
Sun Jun 19, 2016 7:09 pm |
Sweet, thanks. What pump are you running?
Sun Jun 19, 2016 7:10 pm |
96 explorer pump
Sun Jun 19, 2016 7:18 pm |
Much appreciated.
Sun Jun 19, 2016 7:58 pm |
