www.ColoradoClassicBroncos.com - View topic - Dana 44
It is currently Sat Nov 23, 2024 1:12 am
Reply to topic  [ 12 posts ]
 Dana 44
Post Dana 44
The ball joints are frozen in it. I have tried to use penetrating oil and nothing. I tried to heat it up and use a big hammer and still nothing not even a little movement. Any ideas of what else might work.
Mon Jul 25, 2016 5:19 pm
Post Re: Dana 44
Hey Matt you need to pickup my ball joint press kit. It's like a big C clamp with press cups.
Mon Jul 25, 2016 5:45 pm
Profile WWW
Post Re: Dana 44
If you want to drive I'll be happy to let you use my 20 ton shop press. But horseplay is on the right track, I'll add that if you cycle the heat with cooling and a good beating they should eventually loosen up.
Tue Jul 26, 2016 8:54 am
Post Re: Dana 44
Not sure where you're located, but I can offer up my press as well.
Tue Jul 26, 2016 6:28 pm
Post Re: Dana 44
Cool thanks everyone I'll see how far I get and keep you posted.
Tue Jul 26, 2016 7:05 pm
Post Re: Dana 44
Looking for a carrier and ring and pinion with 4.09 or 4.10 gear ratio. Open diff is fine. If anyone has any idea where to get one. I have got prices from 200.00 up to 700.00. I'm a broke white man and can't afford to go new. shrug
Tue Aug 30, 2016 9:12 am
Post Re: Dana 44
I might have one. Can't remeber the ratio I've got, but can look tonight.
Tue Aug 30, 2016 9:40 am
Post Re: Dana 44
That would be great
Tue Aug 30, 2016 12:50 pm
Post Re: Dana 44
Got a lead on a D44 with 4.09 gears along with the whole housing today. He is asking $350. Sound fair?
Plan on going out to take a look at it and see what condition It is in tomorrow morning.
And if I do decide to pick it up I will have a extra housing with 3:54 gears.
Wed Aug 31, 2016 7:17 pm
Post Re: Dana 44
Looks like my gears are 3.5. That price isn't great, but isn't terrible either
Thu Sep 01, 2016 8:57 pm
Post Re: Dana 44
Here's the plan :
Going to get the carrier ,spider gears ,install kit ,axle seals ,ring and pinion.
my question is I have never set up a ring and pinion so where can I go to get it all put in and sealed ? Or who is recommended ?
Fri Sep 02, 2016 3:23 pm
Post Re: Dana 44
Crawler tech 4x4.
Fri Sep 02, 2016 7:57 pm
Users browsing this forum: No registered users and 49 guests
32,963,475 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
