It is currently Thu Nov 21, 2024 1:26 pm
Re: ZOSO's toys
yep thats who I use for all my an fittings and hoses. I got most everything I need I just gotta make sure it'll all fit and under the hood.
Mon Aug 08, 2016 8:02 pm |
Re: ZOSO's toys
Another thing almost complete. Got 90% of the trans cooler lines done. that will be finished tomorrow and will continue on with the wiring.
Mon Aug 08, 2016 8:03 pm |
Re: ZOSO's toys
It's Alive!!!! ish. Needs a tune. Way rich!!! Tuesday Garry should be coming by tuesday to get me a tune. I need to go get my driveshafts built.
Sun Aug 21, 2016 6:10 pm |
Re: ZOSO's toys
Awesome !
Keep going
Sun Aug 21, 2016 7:12 pm |
Re: ZOSO's toys
After having the master EFIguy over for a few hours last night we were unable to get it to run. Weird thing is itll run albeit very rough WITHOUT the fuel pump. After a bit of trouble shooting and washing out the oil again we narrowed it down. Now the in depth trouble shooting starts. For some strange reason neither of us can figure out why but as soon as the key is turned to the on position it powers up all 8 injectors. They are all on/open and do not pulse. So it just fill the engine with fuel. 2 pcm's do it either tuned or factory. The harness ohm's out ok on the injector wiring. Will likely pull the upper intake off next week and start the testing of the harness. Double checking all wiring.
Wed Aug 24, 2016 7:06 am |
Re: ZOSO's toys
It'll be something stupid simple, but finding that could take some time!! Hope you sort it out soon!
Wed Aug 24, 2016 10:17 am |
Re: ZOSO's toys
Sad news, I was hoping for vroom vroom sounds.
Wed Aug 24, 2016 2:59 pm |
Re: ZOSO's toys
VROOM VROOM!!!! It's alive. Couldn't stump the master for very long. He found a corrupted pcm/tune. Once he re-created the tune we have lift off. Now to fix the leaks and burp/bleed fluids and a drive shaft Im gonna drive it around the block.
Wed Aug 31, 2016 6:05 am |
Re: ZOSO's toys
Nice! Congrats!
Wed Aug 31, 2016 7:18 am |
Re: ZOSO's toys
NICE! Congrats
Wed Aug 31, 2016 7:39 am |
Re: ZOSO's toys
Very Nice!
Wed Aug 31, 2016 7:55 am |
Re: ZOSO's toys
Good work guys!! I'm glad it didn't take too long!
Wed Aug 31, 2016 8:03 am |
Re: ZOSO's toys
Awesome news! So we'll be seeing this beast at the next breakfast.
Wed Aug 31, 2016 8:59 am |
TOOLMAN
Re: ZOSO's toys
Wed Aug 31, 2016 10:26 am |
Re: ZOSO's toys
Where's the video?
Wed Aug 31, 2016 10:29 am |
Re: ZOSO's toys
Wed Aug 31, 2016 12:10 pm |
Re: ZOSO's toys
Wed Aug 31, 2016 1:01 pm |
Re: ZOSO's toys
great news Rob.
congrats !
Wed Aug 31, 2016 2:40 pm |
Re: ZOSO's toys
Wed Aug 31, 2016 5:54 pm |
Re: ZOSO's toys
So spent all day Saturday trying to bleed the brakes. Had some messed up bleeders. Went to the parts store 4 times to finally get the correct ones. Got all those put in and no go. Front calipers are screwed up and won't stop leaking. Give up for the day. Today went and bought new calipers. Went to install and the lines don't freaking fit. So I give up. Just push it back I to the corner of the garage and let it sit. Don't see this being done anytime soon. All I wanted to do was drive it around the block.
Sun Sep 04, 2016 4:36 pm |
Re: ZOSO's toys
Give it a day or to Rob. You'll get it going!
What's up with the calipers? Wrong size or a length issue? What brand of caliper?
Tue Sep 06, 2016 10:00 am |
Re: ZOSO's toys
Teaser. I didn't have to push it either.
Sat Oct 01, 2016 12:18 pm |
Re: ZOSO's toys
It's amazing what 50 model rocket engines can do.
Sat Oct 01, 2016 4:01 pm |
Re: ZOSO's toys
Sun Oct 02, 2016 5:37 am |
Re: ZOSO's toys
The question is, "were you able to stop on your own?"
Sun Oct 02, 2016 11:18 am |
Re: ZOSO's toys
Sun Oct 02, 2016 6:23 pm |
Re: ZOSO's toys
Mon Oct 03, 2016 8:50 am |
Re: ZOSO's toys
Pedal feel is weird with the hydraulic booster. Assuming you're bled well you get used to it. It also takes awhile to get all the air out of the booster, so it may take some more driving. You're welcome to compare against my setup at lunch on Saturday.
Mon Oct 03, 2016 12:03 pm |
Re: ZOSO's toys
I think you are on the right track, getting a larger bore M/C. I added the t-bird calipers to my existing H-boost system and it softened the pedal. With the F150 calipers the pedal was very sensitive. I liked it, but it was either on or off & it had rear bias. The bigger t-bird calipers pulled the bias forward and gave a softer pedal, but it's still ok. Any bigger, and I think I'll be looking for a different m/c too.
Mon Oct 03, 2016 12:25 pm |
Re: ZOSO's toys
the camaro master is 1 1/8" bore already. I guess I'll find out how well it works tomorrow hopefully. I plan to bleed them some more when I get home from work just to be safe.
Mon Oct 03, 2016 7:15 pm |
