It is currently Sun Nov 24, 2024 12:44 pm
We need a "You know what sux?" thread....
cravenbronco
Re: We need a "You know what sux?" thread....
Tue Sep 06, 2016 10:30 pm |
Yikes, that's perfectly placed between the tread blocks too!! So sorry!
Wed Sep 07, 2016 7:59 am |
Wed Sep 07, 2016 5:37 pm |
TOOLMAN
...When you fire up the Bronco and you forget it's in gear. Ooopsie.
Thu Sep 08, 2016 9:24 am |
That totally sucks. Is that 2 separate incidences?
Thu Sep 08, 2016 10:24 am |
Gregg
I would have lied and said the "garage door jumped out in front of me"
I'm with Eck--Which jumped out first? The garage or the SUV?
Thu Sep 08, 2016 11:52 am |
TOOLMAN
Thu Sep 08, 2016 12:12 pm |
^ I do believe you win the sux most prize this month!
Thu Sep 08, 2016 4:26 pm |
Oh crap.
Thu Sep 08, 2016 7:28 pm |
That really sucks. It's bad when one vehicle gets damaged. It's really bad when you throw in another vehicle and a garage door. If I hadn't had only auto transmissions for the last 20 some years I'm sure I could have done something similar.
Thu Sep 08, 2016 9:53 pm |
sykanr0ng
Re: We need a
Thu Sep 08, 2016 10:00 pm |
That does suck. I know the feeling. When I was 17 I started my dad's 1983 Porsche 911 in gear. It took off and hit the back of my 1984 Bronco II. The BII moved forward a foot or two, but didn't hit anything, and was undamaged. The 911 had a scraped bumper and crushed headlight rings. Pretty minor, all things considered.
I'm still extra careful starting manuals. It makes quite an impression.
Fri Sep 09, 2016 12:02 am |
I've been extra careful with mine but have started it a few times in gear but always with my foot on the brake. (Thank god for hydro boost) Still moves a few feet. Scares the crap out of me cause I think the bronco won't stop once started and will drive over or push whatever is in front/back unless that whatever is immovable.
Fri Sep 09, 2016 7:58 am |
airbur
Wow...these are all horribly awesome. Glad to see the thread still up and popular.
Fri Sep 09, 2016 1:02 pm |
Brakes. They suck!!!! It's been an on going battle just to bleed the brakes. First it was a bad flair on a line. then it was a broken bleeder screw. Then a messed up caliper. new calipers don't fit the old hoses and banjo bolts. New braided stainless lines are not the size they said they are. So now those don't fit the new calipers either.
Tue Sep 13, 2016 7:12 am |
So many variables in a retro-fitted brake system!
Wed Sep 14, 2016 8:41 am |
That's weird. I used bc's hoses and they were great. What calipers are you running?
Wed Sep 14, 2016 9:01 am |
Wed Sep 14, 2016 1:45 pm |
Replacing the front axle u-joints in my pick-up. Having to buy not 1 but 2 new sockets, and one is a 1-11/16, 3/4 drive. It is so tight I break my 1/2" driver breaker bar and have to go buy a 3/4" breaker bar. Still need 5' of pipe and my fat butt jumping up and down on it to break it free.
Get the husband bearing replaced, remove the old u-joint and the parts store sold me the wrong u-joints.... So off to oriely to exchange (this time bringing the outer. Axle with me. Finally get the u-joint in and finish the driver side. Jack the passenger side up and voila.....
Right side inner seal is leaking. Looks like I am playing in the garage next weekend too
Sun Sep 25, 2016 6:49 pm |
Sun Sep 25, 2016 7:37 pm |
Sun Sep 25, 2016 8:15 pm |
The one that broke was not subjected to this level of abuse. I was actually lifting trying to turn that castle nut. Spec is 175lbs torque and this one had not been loosened since it was first installed in 2001
Sun Sep 25, 2016 9:26 pm |
You know when you buy a Bronco sight unseen and the Previous Owner tells you how nice it is and how you won't be disappointed.....until it arrives like this!!!
Good thing I took 1 last pic of Hammed as he loaded it!
Tue Oct 04, 2016 12:12 pm |
Ouch!
Tue Oct 04, 2016 2:41 pm |
Unbelievable. Seriously, is there no pride in doing your job anymore? That is a disgrace.
Tue Oct 04, 2016 5:18 pm |
cravenbronco
Wow. Just shows how the world is going down the tubes
Tue Oct 04, 2016 8:29 pm |
Wed Oct 05, 2016 10:44 am |
Yesterday afternoon digging through the parts stuff and I find this snap ring with the Trans stuff. Just what I needed. Guess it was time to drop the pan and valve body and see if it is the overdrive servo retainer. Well good news is it wasnt. Bad news is I have no itldea what it goes to. I've been over everything in the Trans and can not remember where this goes. Oh well I'll drive it till it breaks.
Sat Oct 08, 2016 7:33 am |
Gregg
Is it your nipple ring?
Sat Oct 08, 2016 9:10 am |
That is a servo snap ring.
Sat Oct 08, 2016 10:27 am |
Users browsing this forum: No registered users and 32 guests |
