It is currently Sat Nov 23, 2024 11:14 pm
Black Smoke Donkey
It's not finished yet, I picked up some left over hardtop pieces from Don's yard a while back that will allow me to make a 4 door "1/2 cab." Should be pretty slick when I'm done.
I also need to rework a bulkhead I have to make a nice closure with the lift gate.
Thu Sep 24, 2015 6:39 pm |
Re: Black Smoke Donkey
So it'll be like a Hummer truck with a removable top and liftgate to get into the cab?
Thu Sep 24, 2015 7:01 pm |
The Hummer's swappable parts has always inspired my build plans. If I stay on track I'll have 3 different top styles and two door styles.
Fri Sep 25, 2015 8:00 am |
It's been way too long since I put anything in this thread.
I was able to sneak away weekend before last and do little camping, fishing & shooting with my youngest. I was itching to try out a couple of additions, the ARB awning & room kit were very nice. Good times.
ImageUploadedByTapatalk1466185711.700932.jpg ImageUploadedByTapatalk1466185746.783807.jpg
Fri Jun 17, 2016 11:50 am |
I can't wait to go camping again! Thanks for bringing back memories!
Fri Jun 17, 2016 1:02 pm |
Zenzone
Very cool! Where did you go camping at?
Fri Jun 17, 2016 1:03 pm |
cravenbronco
Fri Jun 17, 2016 1:07 pm |
I like your style
Fri Jun 17, 2016 3:37 pm |
Sat Jun 18, 2016 5:08 am |
Quick overnight up by Mt Evans while attending a trail design course. At this pace I may get in two camping trips a month this summer.
Mon Jun 20, 2016 11:47 am |
The eventual has happened, I was going to reinforce this area when I did my D60 swap.
ImageUploadedByTapatalk1467034109.392949.jpg ImageUploadedByTapatalk1467034120.626744.jpg ImageUploadedByTapatalk1467034132.628756.jpg
Two bolts broke & the third ripped through the frame, I'm curious which failed 1st, bolts or frame. A loud pop preceded the mayhem.
I'm happy that 2 of the 4 bolts that I used to secure my winch to the frame were Grade 8 & the right size so I could limp home.
Mon Jun 27, 2016 7:32 am |
OUCH !
Mon Jun 27, 2016 9:00 am |
I see a missed opportunity to try out that new portable welder.
Mon Jun 27, 2016 9:29 am |
Black Smoke Donkey
If only I had it in the Bronco at the time, it was suppose to be a nice easy get away with the pup. It'll ride along from now on.
Mon Jun 27, 2016 11:14 am |
Glad you're safe. That could have been bad!!
Tue Jun 28, 2016 12:04 am |
Damn, that sucks. Glad you're alright.
Tue Jun 28, 2016 12:13 am |
It was a slow speed event, I was backing up the trail to take a different spur. I was at full steering wheel lock in a rut with the pop up camper on the back and in 4x4 low.
I repaired the frame last night and cut the pieces for the plate reinforcement. I did notice that one of the cracks had rust along the break so this area was weak and ripe for failure.
Tue Jun 28, 2016 6:57 am |
Black Smoke Donkey
Back from hunting, sadly no elk in the cooler, but my boys and I had a great time. It's the 1st time we all hunted big game together, we pushed into the back country with backpacks and got away from the crowds for a couple of days.
BSD got its usual workout, luckily no problems this year. I ran it over the scales on my way back home and hit 9865 lbs combined weight loaded. Split out the weight and the Bronco was 6605 lbs, trailer was 3360 lbs, and ~ 580 lbs of tongue weight. The 4bt I have is rated for 10,000 lbs, so I'm done adding weight, mostly. Except for those axles I plan on installing.
I'm really happy that I run mud tires, they don't get used very often, but man they saved my bacon this last week. I wish I had video of the slick hill I pulled to get out of hunt camp, the smile on my face was priceless.
Below pic is what the rear tires kicked up onto the trailer.
ImageUploadedByTapatalk1477059505.938130.jpg ImageUploadedByTapatalk1477059514.293171.jpg ImageUploadedByTapatalk1477059521.941619.jpg
Fri Oct 21, 2016 8:04 am |
Sorry to hear you didn't get your elk, but I know it was way worth it spending time with your sons! And congrats on a successful trip in the bronco! I am glad that it's working out for you!
Nice Beard!!!
Fri Oct 21, 2016 8:35 am |
Great times whether you got an elk or not.
That picture of you and your boys is awesome !
Fri Oct 21, 2016 9:07 am |
rt9
Very Cool!!
Fri Oct 21, 2016 9:53 am |
Colorado75bronc
Sorry to hear about no elk, but glad you still got to get out and enjoy the time with your boys! The bronco is looking awesome and sounds like it's accomplished everything you want it to with ease!
Fri Oct 21, 2016 10:01 am |
cravenbronco
Fri Oct 21, 2016 12:11 pm |
Zenzone
Looks like a great time! The memories you make on those trips will stick with you forever! Glad your bronco is performing great.
Fri Oct 21, 2016 2:01 pm |
Fri Oct 21, 2016 7:58 pm |
D&D72
Time with the boys and BSD performing well. Win Win in my book! Excellent selfie with the boys too.
Sat Oct 22, 2016 8:46 pm |
cravenbronco
Sun Oct 23, 2016 8:20 am |
So when do you set yours up with something like this?! Sent from my iPhone using Tapatalk
Wed Jan 24, 2018 6:17 pm |
Bronco tow truck setups are always cool, I’d love it if BSD had a gas station logo on the door like Shawn’s Junkyard Dog!
Wed Jan 24, 2018 7:27 pm |
I have an airbrush....
Sat Jan 27, 2018 7:43 pm |
