Register •
FAQ
• Login
It is currently Sat Nov 23, 2024 12:56 am
[ 6 posts ] |
Tcase pops in neutral.
On my drive to elk camp and each down hill section on the highway as I'm coasting the tcase pops into neutral. Never had this issue until now. What causes this?
Sun Oct 23, 2016 2:38 pm |
horseplay
Re: Tcase pops in neutral.
You may have weak or worn detent springs & balls.
Sun Oct 23, 2016 2:43 pm |
Lots of potential causes in addition to weak springs; shifter contacting floor, loose or worn shift forks, worn input gear, excessive output shaft end play, bent or imbalanced driveshaft.
Sun Oct 23, 2016 2:54 pm |
Bet it is driveline vibration. Never had this issue or driveline vibration until the 4r70w swap.
Mon Oct 24, 2016 12:10 pm |
What flexplate did you use?
Mon Oct 24, 2016 1:08 pm |
The one that was on it. It is not a driveshaft vibration. Reving in neutral or park above 2k rpm I get a vibration from either engine or trans.
Tue Oct 25, 2016 4:33 pm |
[ 6 posts ] |
Users browsing this forum: No registered users and 37 guests |
