www.ColoradoClassicBroncos.com - View topic - First Time Bronco Owner - 1969 Bronco
It is currently Wed Dec 04, 2024 2:20 am
Reply to topic  [ 170 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
Post Re: First Time Bronco Owner - 1969 Bronco
Fri Nov 18, 2016 11:33 pm
Took out the old cage and test fit the new one, it actually fits really well. Going to be pulling it back out for paint.
Sat Nov 19, 2016 10:53 pm
Looks good! Nice touch with the student driver sticker. icon biggin
Fri Nov 25, 2016 9:54 am
Wed Nov 30, 2016 10:26 am
It's going to be an amazing build!
Wed Nov 30, 2016 10:40 am
Wed Nov 30, 2016 10:56 am
Stopped to check on my axles today and the rear is ready to go.
Thu Dec 01, 2016 12:53 pm
Very nice ! did you use a disc brake conversion kit for the 9"? if so what brand. I really like those beadlocks where you able to get the tires balanced or are you using bb's. Bronco looks awesome!!
Thu Dec 01, 2016 2:01 pm
Thu Dec 01, 2016 2:13 pm
Thu Dec 01, 2016 5:12 pm
Been making progress and hoping to get a lot done over the next month while I am on break. Started picking up stuff for the ZF5 swap:
Have/enroute
ZF5
Cross member
Master cylinder/clutch rod
Clutch pedal
Upper shifter
Flywheel
Need to get
Clutch set
Slave cylinder
Engine plate (what works?)
Anything I am missing?
Fri Dec 09, 2016 7:13 pm
Do you have the clutch line? Also- the fluid? I recommend the Redline MTL.
Sat Dec 10, 2016 1:59 am
If you end up buying an Atlas, I have a 3/4" spacer kit that I didn't use. Let me know if you need it.
Sat Dec 10, 2016 8:16 am
The process of tubing the front and the axle swap are getting started.
Sun Dec 11, 2016 12:47 am
Yeah, I'd say it's started alright! Wow!
Sun Dec 11, 2016 12:52 am
No turning back now!
Sun Dec 11, 2016 8:12 am
It will be fine, tube work is going to be kind of like the Scout below, all the stock sheet metal will bolt back on. Threw in a shot of the front axle almost done. I am looking forward to seeing how the tube work comes out.
Sun Dec 11, 2016 8:39 am
Looking good
Sun Dec 11, 2016 8:50 am
Whoa, at first glance I thought "how the hell did he get that thing painted so quick?"
Looks like your gonna have a nice and capable rig when your done !
Sun Dec 11, 2016 9:21 am
Front end waiting on hubs while the motor gets buttoned back up. Went to do the Explorer front dress swap and found some leaks and the need for a new timing chain, gears, and oil pump.
Wed Dec 14, 2016 4:48 pm
I think I am having withdrawals since my Bronco is in the shop getting tube work, etc. done. Got a chance to do some Bronco related work today. Picked up stuff from powder coating and started reassembly. Pedals are now ready for the ZF5 swap and rebuilt with all new bushings and pads.
Mon Dec 26, 2016 10:09 pm
Wow, that'll be purdy!!
Tue Dec 27, 2016 9:19 am
Those are nice! I didn't know Santa powder coated.
Tue Dec 27, 2016 9:30 am
Tue Dec 27, 2016 10:25 am
That looks killer! I can't wait to see this rig flexed out on rocks!
Tue Dec 27, 2016 10:49 am
That looks great. I'm jealous, I wish I had a tubing bender (and the skills to use one).
Tue Dec 27, 2016 1:24 pm
Tue Dec 27, 2016 1:49 pm
Looking good can't wait to see it in person.
Wed Dec 28, 2016 11:01 am
Vey Cool tubing work looks great!
Wed Dec 28, 2016 3:04 pm
Transmission and T-case swap getting started, ended up pulling the motor since it was only bolted to the trans. Having the tubing removable is working out well.
Sun Jan 08, 2017 12:22 am
33,208,612 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
