www.ColoradoClassicBroncos.com - View topic - My Bronco starts easily - even in chilly 3 degree weather.
It is currently Fri Nov 22, 2024 9:46 pm
Reply to topic  [ 9 posts ]
Post My Bronco starts easily - even in chilly 3 degree weather.
I just wanted to put the word out that you CAN have a carburetor and have it run well.
My Bronco starts right up after sitting for weeks in the winter outside...no issues.
Warms up in a minute or two and ready for the road.
Just a FYI as there is a perception that you need a EFI to make a Bronco run well.
I love my Bronco!
Erik
Thu Jan 19, 2017 3:54 pm
Post Re: My Bronco starts easily - even in chilly 3 degree weathe
Yah? Next test is to sit in I-70 rush hour when it's 98 degrees outside and not get vapor lock... Good luck with that one!
Thu Jan 19, 2017 6:23 pm
Fri Jan 20, 2017 10:08 am
Fri Jan 20, 2017 11:46 am
What are you using to insulate?
Fri Jan 20, 2017 6:29 pm
I believe that a well tuned carb can perform pretty well for a lot of situations. It's not a requirement to go to efi, but there are many off-road situations where the carb will not work or will flood out. Only bronco I'd consider keeping the carb on is a stocker that I'm trying to keep original.
Tue Jan 24, 2017 4:07 pm
Both my broncos had run edelbrock carbs and once tuned right they didn't have any issues.
As a note, just wrapping the fuel lines with a thermal wrap wont prevent vapor lock. I had it figured out on my 79 where it wouldn't vapor lock but the most extreme heat. And even my efi on the 74 vaporlocked in 75* weather.
Wed Jan 25, 2017 2:11 pm
Tue Apr 11, 2017 8:44 am
Tue Apr 11, 2017 4:09 pm
Users browsing this forum: No registered users and 44 guests
32,959,228 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
