It is currently Fri Nov 22, 2024 9:25 pm
[ 9 posts ] |
My Bronco starts easily - even in chilly 3 degree weather.
Unaweep
I just wanted to put the word out that you CAN have a carburetor and have it run well.
My Bronco starts right up after sitting for weeks in the winter outside...no issues. Warms up in a minute or two and ready for the road.
Just a FYI as there is a perception that you need a EFI to make a Bronco run well. I love my Bronco!
Erik
Thu Jan 19, 2017 3:54 pm |
Re: My Bronco starts easily - even in chilly 3 degree weathe
Yah? Next test is to sit in I-70 rush hour when it's 98 degrees outside and not get vapor lock... Good luck with that one!
Thu Jan 19, 2017 6:23 pm |
Fri Jan 20, 2017 10:08 am |
Unaweep
Fri Jan 20, 2017 11:46 am |
What are you using to insulate?
Fri Jan 20, 2017 6:29 pm |
I believe that a well tuned carb can perform pretty well for a lot of situations. It's not a requirement to go to efi, but there are many off-road situations where the carb will not work or will flood out. Only bronco I'd consider keeping the carb on is a stocker that I'm trying to keep original.
Tue Jan 24, 2017 4:07 pm |
Both my broncos had run edelbrock carbs and once tuned right they didn't have any issues.
As a note, just wrapping the fuel lines with a thermal wrap wont prevent vapor lock. I had it figured out on my 79 where it wouldn't vapor lock but the most extreme heat. And even my efi on the 74 vaporlocked in 75* weather.
Wed Jan 25, 2017 2:11 pm |
Unaweep
Tue Apr 11, 2017 8:44 am |
Tue Apr 11, 2017 4:09 pm |
[ 9 posts ] |
Users browsing this forum: No registered users and 55 guests |
