It is currently Sun Nov 24, 2024 7:46 pm
BroncoRaider
Black Smoke Donkey
Tue Feb 07, 2017 6:05 pm |
Re: Black Smoke Donkey
Far better than the response on Facebook yesterday.
Tue Feb 07, 2017 6:13 pm |
Tue Feb 07, 2017 6:17 pm |
Tue Feb 07, 2017 6:27 pm |
Tue Feb 07, 2017 11:04 pm |
TOOLMAN
Wed Feb 08, 2017 7:50 am |
Some folks just lack vision. I feel sorry for them...
Wed Feb 08, 2017 9:20 am |
And not one comment about the pre-runner front fenders....
I know this, every time he shows up at a breakfast, his rig gets more attention from outsiders than most, if not all the others combined. Must be the end of the world SHTF appeal. If he ever gets the sound proofing done, we will all want to ride along with him.
Wed Feb 08, 2017 10:46 am |
Man oh man! Thanks fellas for defending me on the national stage!
Thu Feb 09, 2017 12:33 pm |
Finally getting to my axle upgrade, seriously needed as I have broken enough axles and u-joints and also crushed enough pinion parts to know my 1/2 ton axles won't last beyond street driving.
Starting with the rear D60 since it'll be a little easier, cutting off the factory spring perches and moving RuffStuff replacements inboard, upgrades will be an ARB and torque tamer.
Wed Feb 22, 2017 12:57 pm |
What's that out of and what brakes are those?
Wed Feb 22, 2017 7:53 pm |
I think that's out of a late 90's E350 if I remember right.
Wed Feb 22, 2017 8:04 pm |
Black Smoke Donkey
Yep, 99+ E350, nice axle with factory disc brakes and cable actuated e-brake. This one is setup with LS and 410s, shame I'm dropping the ARB and 350s into it for my diesel.
Mocking up the new spring perches, might get it under BSD by the end of the weekend. I still need to decide if I'm leaving the flange on it, right now I'd like to keep it.
Thu Feb 23, 2017 2:31 pm |
You have 8-lug wheels lined up?
Thu Feb 23, 2017 3:47 pm |
Thu Feb 23, 2017 5:40 pm |
Thu Feb 23, 2017 6:03 pm |
Thu Feb 23, 2017 7:22 pm |
Thu Feb 23, 2017 7:29 pm |
and that D60 should accept 35 spline axles.
Thu Feb 23, 2017 9:51 pm |
Thu Feb 23, 2017 10:46 pm |
TOOLMAN
Fri Feb 24, 2017 8:10 am |
Black Smoke Donkey
Installed after a week wait to source the right U bolts, who knew the E350s used Superduty spec'd axles. I'll get the rear fenders opened up and mount the matching fiberglass. I'll be in fwd for a week until the driveshaft is modded.
Sat Mar 18, 2017 2:21 pm |
Nice rimz!!!
Sat Mar 18, 2017 4:43 pm |
Black Smoke Donkey
I love the 8 lug look. Even better for strength!
Sat Mar 18, 2017 8:58 pm |
Sat Mar 18, 2017 10:13 pm |
Looks great! What tire size did you end up on?
Sat Mar 18, 2017 11:13 pm |
Black Smoke Donkey
Sun Mar 19, 2017 3:08 pm |
looks good Kirk. Get those rear quarters on and some paint.
Sun Mar 19, 2017 5:45 pm |
I have some concerns of that wrap trap making your truck ride rough. As your suspension compresses the axle moves backward slightly, but with that trap all tightened up, you are hindering that movement. Perhaps there is something there I am not seeing and knowing you, there is, but I've seen a lot of folks run similar designed ladder bars and complain of rough riding.
Mon Mar 20, 2017 10:01 am |
I have the same wrap trap - I haven’t noticed any ride issues as its not a solid piece technically, there is a bushing on one end that absorbs shock and vibration. Matter of fact it saved me in moab when i lost one of my centering pins on my rear leafs early on Poison Spider - i wheeled most of the day with just one pin and that wrap trap.
I am a fan especially with the torque my engine makes as I would have lost my driveshaft and probably leafs quite a while ago without it. Not to say there isn’t anything better - it seems to work for me :)
Mon Mar 20, 2017 10:08 am |
Users browsing this forum: No registered users and 100 guests |
