www.ColoradoClassicBroncos.com - View topic - Stumble stumble
It is currently Fri Nov 22, 2024 9:54 pm
Reply to topic  [ 14 posts ]
 Stumble stumble
Post Stumble stumble
My new 351w now has 6000 kick ass miles on it. It runs very nice and I love the sound and feel.
Meanwhile, I continue to have an irritating stumble that I can't solve.
It only happens between 2900 - 3300 rpm. I have a digital tach which I have been watching very close and the stumble is very consistent and predictable within the range I mentioned. I'm not sure stumble is the right word. It's more like a series of dead spots within that range. When it "stumbles" it's kind of like the ignition goes completely dead for a nano-second and then right back to good.
I have good fuel pressure and the spark plugs look good. No codes on the computer either.
I thought it could be dead spots in throttle position sensors but I swapped in my spare tps sensor without solving the problem.
So, let's hear your ideas and recommendations and actions !
Thu Feb 16, 2017 9:58 pm
Post Re: Stumble stumble
Coyote
Thu Feb 16, 2017 10:05 pm
Sounds like a possible pickup sensor
Thu Feb 16, 2017 10:13 pm
Profile WWW
Fri Feb 17, 2017 3:06 am
Do you have a Knock Sensor?
Fri Feb 17, 2017 9:27 am
Fri Feb 17, 2017 11:07 am
It's all Explorer stuff.
So no knock sensor that I'm aware of.
Fri Feb 17, 2017 11:39 am
I would check the integrity of all the cam position assembly from connector to drive gear.
Fri Feb 17, 2017 5:10 pm
Profile WWW
these are the same injectors that were on the 302 right? I wonder if you have a bad one somewhere.
Fri Feb 17, 2017 9:14 pm
Fri Feb 17, 2017 9:16 pm
Fri Feb 17, 2017 9:18 pm
Fri Feb 17, 2017 9:25 pm
If it does stick a timing light on each plug wire. Then also open the injector harness and do each injector. It should pick it up if it's one of those.
Fri Feb 17, 2017 9:29 pm
Just getting back to planet Bronco after two long weeks of business travel.
I wiggled all the cam position wiring / connectors and problem remains.
Sounds like I need to check gear and then move on to plug wires and injector wires, etc
Mon Mar 13, 2017 3:32 pm
Users browsing this forum: No registered users and 43 guests
32,959,533 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
