cravenbronco
Death wobble
It just started today. Was going slower speeds like 10 20 mph when the whole Bronco started to shake really bad to the point of almost having to come to a full stop be for it would quit. Would king pins cause this problem or should I be looking elsewhere?
Sat Feb 18, 2017 1:58 pm |
Re: Death wobble
Or ball joints (if d44) or trackbar bushings.
Sat Feb 18, 2017 1:59 pm |
horseplay
Re: Death wobble
Which truck Matt big blue or the half cab two different set UPS
Sat Feb 18, 2017 4:41 pm |
cravenbronco
Re: Death wobble
Sat Feb 18, 2017 8:32 pm |
Re: Death wobble
I would check the trackbar first.
Sat Feb 18, 2017 10:23 pm |
Re: Death wobble
I'd start be replacing all the front end bushings including the c bushings. An afternoon of work and not too expensive!
Sat Feb 18, 2017 10:45 pm |
Re: Death wobble
x3 or whatever on the track bar bushings. If that doesn't do it, I'd go through the rest of the bushings in the front end.
Sun Feb 19, 2017 12:15 am |
rt9
Re: Death wobble
X4, this solved the problem on mine.
Sun Feb 19, 2017 7:43 am |
horseplay
Re: Death wobble
Hey Matt because your swapping in the D44 I wouldn't get to busy unless it's just the track rod bushings.
Sun Feb 19, 2017 10:47 am |
cravenbronco
Re: Death wobble
Sun Feb 19, 2017 1:27 pm |
Re: Death wobble
Have someone steer the wheel back and forth from say 10 o'clock to 2 while you start looking for play from track-bar all the way to the steering box.
Mon Feb 20, 2017 9:23 pm |
cravenbronco
Re: Death wobble
Thanks again for the input it sure helps out. My findings: I had someone move the steering wheel and found that both of my tie rod ends were way loose once I tightened them up the cotter pins didn't even touch the castle nut so I added some washers and now it's good to go. I also had boots ripped so those got replaced. Greased and once again it's a happy truck.
Tue Feb 21, 2017 6:20 pm |
