www.ColoradoClassicBroncos.com - View topic - Flutter on acceleration--fixed
It is currently Fri Nov 22, 2024 9:44 pm
Reply to topic  [ 11 posts ]
Post Flutter on acceleration--fixed
I drive my (explorer swapped 5.0) Bronco nearly everyday and it started making a flutter sound (not ticking) coming home. It only happens during moderate to heavy acceleration. Maintaining a speed doesn't seem to recreate the sound. No engine light. I checked the headers and I didn't see any exhaust residue (yet) and the bolts were still tight. The only thing that changed were adding a 1/2 quart of oil (it was a little low).
Any ideas where to start?
Mon Mar 06, 2017 7:27 pm
Post Re: Flutter on acceleration
Mon Mar 06, 2017 7:45 pm
I set the TPS at .96 a month ago
Cleaned the MAF about 2 months ago. I'll look again tonight.
I disconnected the battery last night to clear anything including my radio stations.
Tue Mar 07, 2017 1:00 pm
Hopefully you used MAF cleaner and not something like brake cleaner.
Wed Mar 08, 2017 6:39 pm
Try a new fuel filter.
Wed Mar 08, 2017 8:16 pm
Thu Mar 09, 2017 1:23 pm
Post Re: Flutter on acceleration--fixed
Yup that collector gasket must have been it. Although having Moab Mikes girlfriend cross her legs probably helped too.
Thu Mar 09, 2017 6:12 pm
Awesome
Thu Mar 09, 2017 8:54 pm
Nice easy fix! I just found the rear most bolts on my headers had worked loose as well so tightened those up and the engine sounds so much better. Curious why that happened and if I was supposed to loctite those bolts?
Thu Mar 09, 2017 9:48 pm
I've just tightened them ocassionally. Red loctite might handle the temps, but I don't want to deal with having to warm it up to loosen the bolts.
Fri Mar 10, 2017 7:55 pm
For headers you just have to keep checking until they stay tight. Took 2-3 times for mine over several months.
Sat Mar 11, 2017 8:49 am
Users browsing this forum: No registered users and 44 guests
32,959,125 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
