www.ColoradoClassicBroncos.com - View topic - Radiator options
It is currently Fri Nov 22, 2024 9:37 pm
Reply to topic  [ 24 posts ]
 Radiator options
Post Radiator options
5.0 explorer swap. I know some have used the original bronco radiator but, what are some of your experiences with other radiators? including an explorer rad?
Mon Mar 13, 2017 9:23 pm
Post Re: Radiator options
The best radiator I ever had in a Bronco. https://www.summitracing.com/parts/sgt- ... del/ranger
Also the cheapest. Now I have one in both.
Mon Mar 13, 2017 11:26 pm
So, that has 1 1/2 " pipes on it. what did you find for hoses? And, what kind of temps were you seeing on a hot day?
Tue Mar 14, 2017 9:50 am
Tue Mar 14, 2017 12:19 pm
thumbs up thanks Phil!
Tue Mar 14, 2017 3:13 pm
I have the part number tags on my tool box and will post them up shortly
I believe this radiator is the cat's meow. I don't have a shroud on mine and it has gotten up to 199 but tomorrow will be first warm day so I will give it another test.
Tue Mar 14, 2017 6:58 pm
Glad to know. I'll be in the market shortly. If you can post the mount part nu,bets I'd be mighty appreciative.
Tue Mar 14, 2017 8:19 pm
The mounting tabs I used were found on the ground at the pull n pay place so I don't have part number / application information.
Most late model ford cars and trucks use various styles of this mount. It has a hole and a rubber grommet in it and a tab on the bottom of the radiator drops down through the hole.
Wed Mar 15, 2017 2:42 am
well I guess I'll be making a pull and pay run. I'll get multiples off a ranger or something to cover you too Justin.
Wed Mar 15, 2017 2:46 pm
That'd be awesome, thanks!
Wed Mar 15, 2017 8:52 pm
Still waiting on those part numbers from Jeffro..... shrug
Wed Mar 15, 2017 10:27 pm
I saved this thread about the 4.0 radiator
http://classicbroncos.com/forums/showth ... p?t=258896
Phil's post about hoses
http://classicbroncos.com/forums/showpo ... ostcount=8
Another
http://classicbroncos.com/forums/showpo ... stcount=12
Don't know if there is a better choice.
Wed Mar 15, 2017 11:12 pm
Thanks Chad.
Thu Mar 16, 2017 2:51 am
Thu Mar 16, 2017 6:15 am
Thu Mar 16, 2017 6:32 am
Thu Mar 16, 2017 7:52 am
Thanks fellas, I got it all dialed in now (I think)
Phil, one other item I am looking for is the mounting bracket for the PS reservoir like yours. I have the reservoir but, not the bracket.
I can make one but, I'm all about easy!
Thu Mar 16, 2017 9:31 pm
It's the stock bracket for that reservoir. L-shaped with slots for the rubber grommets.
Fri Mar 17, 2017 7:33 am
[quote="Viperwolf1"]It's the stock bracket for that reservoir. L-shaped with slots for the rubber grommets.
What make/year is that reservoir from?
Fri Mar 17, 2017 11:20 am
I think mine was off a mid 90s diesel excursion. Cost me about $45 with the bracket off fleabay, but took a little searching to find one.
Fri Mar 17, 2017 11:48 am
Fri Mar 17, 2017 1:30 pm
Fri Mar 17, 2017 2:54 pm
Yes, sorry, mid 2000s. Viper is right
Fri Mar 17, 2017 3:00 pm
The reservoir was easy to come by. bracket not so much.
Fri Mar 17, 2017 8:32 pm
Users browsing this forum: Google [Bot] and 55 guests
32,958,846 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
